hid's
ok or you can keep talking about information some one else posted for you, about a headlight you have never seen in person. if you wanted to be an technical about everything on the road why dont you just go into the general performance section and tell people not to remove their catalytic converters because they will hurt other peoples ears. if your going to bitch and moan about a product you have never seen in a camaro in person, then how can you give out information about it
you started the argument telling him not to do it. im simply saying he should.
your conversion isnt even finished yet,
mine cost me $50 and ten minutes and it produces a great pattern that isnt blinding to oncoming traffic
see them all over town and they dont bother my eyes
imagine everyone passing you at night having their high beams on, but they are twice as bright. thats what will happen if you put the in your lows. anyone who puts HIDs in stock housings is a cheap *******, and theres no getting around it.
Lol actually I don't have the stock headlights on my truck they are some sylvania replacements that were made for hids but they still are not projector lenses. To each there own I guess.
That will be me until I find projectors I like.
There are HID reflectors out there so if that is what you have replaced your stock housings with thats cool. light should be decently controlled.
Been done for a week. Would have been far sooner If it was an issue and i had not second car. About 2 days of real work would do it.
Keep telling yourself that. Better yet. PROVE it. park 25-30ft from a white wall and show us your low beam pattern. Until then I will always maintain HIDs in any halogen housing = BAD blinding pattern. BTW that is also the position of the NHSTA. It was the reason for the massive crackdown on those companies importing the HID kids until they got slick and just branded them "For Off Road Use Only". Which prevents the goverment from doing much of anything to them. Now they can only go after users.
none of the kits are branded off road use only because they still are deemed unfit for use. just an FYI as im sure you know your projector housings are still illegal
I doubt you know what your seeing. There are HID Reflector designs out there and those are likely what you see.
just an fyi there is still a huge difference between the low beams and high beams. low beams are merely semi circles for the bottom half of the road and the high beams are still for the top half. no that doesnt mean that my HID kit isnt producing better light output, low beams are still 2x as bright as silverstars, the high beams just have a better pattern from the headlight housing to display the most light over the most possible area
even with my hid kit my high beams are still 2-3x brighter because they have a more disperse pattern.
i understand you guys are working for the greater good, but the camaro healdights still are the very best units for a plug and play h.i.d. kit. i gave the local hid distributor a ride in my car and he admitted that hes never seen such a good cutoff from stock healdights
i will try to take some pictures like that for you shortly, they look like semi circles against the wall from that distance
chrysler kid, I've seen and been blinded by enough HIDs in reflector housings of various types. I can literally stand in front of my car with projectors and not get blinded because the light is projected where it should be.
Case closed.
Case closed.
If they don't brand them as Off-Road use Only then the NHSTA may start chasing them again. ORO markings make pretty much any lighting you want to install acceptable as when your running around in the dirt or fields, maximum lighting without concern for highly controlled beam pattern is what those folks are really after. thats why the Off Road marks let them get away with importing into the USA. I could take a 300watt incandesent bulb. mount it into a bowl reflector and use that if i wanted to offroad. ORO=Unfit for road use. But when 4 wheeling or such There is no real worries about other drivers. encounters are minimal and many kill their mega light bars when facing other drivers.
off road use only is about as valid as the DOT symbol on the box that came with my kit. it may pertain to the ballast in some way, but not the bulb or for its intended use
i can stand infront of my car with the headlights on and stare in them aswell. get on your knees to pattern level and you will still get blinded by the high light output from your projectors.
the only argument you have to the projectors is light scatter and the camaro headlight doesnt produce hazardous levels of output. it still has a good cut off, so please inform me how a properly aligned headlight with a hid bulb with minimum scatter is any less blinding above the cutoff level than a projector? ITS NOT your still putting out high amounts of light below the cutoff level. with the scatter shield, and only a curved reflective backing (unlike the typical dome shape) the camaro headlights have an acceptable cutoff level
if you dont have the proper cutoff level in any projector housing your still going to blind people.
please tell me where in my picture you see evidence of high amounts of glare and in proper cutoff? my friend has a dakota with absolutely no cutoff in the patter, and if it wasnt for his headlights being completely glazed over and yellow it would be very blinding, but lumping a headlight with a good design into that category is like me saying that a gun can kill you so everyone should buy knife's.
heres a picture showing a horrible projector setup on an sc300. there still seems to be no cutoff level to the output of light
Mazdaspeed 3 with HID kit in factory projectors. still more glare than my camaro
AND by far the WORST retro fit i have ever seen, these projectors have no blocking plate and scatter light everyhwere!
im not arguing that a hid bulb in a non projector housing isnt dangerous, im arguing that the camaro headlight is not dangerous
here is a picture that shows how stupid bright a hid bulb in a halogen housing can be, look at the glare on the ceiling!
#32
go back through some of the old argument threads. i can stand infront of my car with the headlights on and stare in them aswell. get on your knees to pattern level and you will still get blinded by the high light output from your projectors.
I tell you what, I'll do it for you.
Here is my car w/ HIDs and STOCK camaro headlight housing. The HID is 6000 K.
Exhibit A:
Exhibit B:
Exhibit C:
Scattered blinding light anyone?
Now here is my new HID projector headlights, the same 6000K but H1 style instead of stock size bulbs.
#33
I see alot of useless rambling from C-Kid to try to hide the fact he can't produce the pictures requested.
BTW C-Kid ALL digi-cameras hate headon shots of light sources like headlights that are surrounded by darkness. the CCD and CMOS chips just can't handle it and makes everything look like it has serious glare. Which is why I want you to get output shots against a white wall. Once the lightsource is surrounded by some other light as well, the CCD isn't so overloaded and can handle the brighter source in a scene far better.
#34
#35
Why don't you get a picture of your car in pitch dark, front and side view and your HIDs ON w/ stock camaro headlights.
Exhibit A:
Exhibit B:
Exhibit C:
Exhibit A:
Exhibit B:
Exhibit C:
#36
#37
i think i see bigfoot in those pictures. the light poles are producing just about the same amount of glare in your background. the camera is so blurry its just taking everything in as glare. your standing above the cutoff line, how about you get a little lower and see if your camera stars blurring photos from glare.
You didn't see the point. I didn't have to go lower to take pictures of the car to see the glare of my HIDs w/ stock headlights and I took the pictures with the HID/Projectors lights with similar angle, standing up.
I didn't have to take the pictures a little lower because as you can see, the cut off line is already below the tail lights and the side view mirror not like the HID w/ stock headlights you would see hot spots EVERYWHERE behind my G35. Honestly, my camaro is parked upwards on the incline so cut off line is actually lower than that.
Also if I took them both kneeling down it would be pointless. It's like looking direct into the sun.
And how can you say the picture of the HID w/ stock headlights blurry? LoL. I can read the freaking letter in the pictures. The only thing blurry is the lights of the moving car and the glare of the street light which is BRIGHT to begin with.
