Removing factory stickers
I want to remove the stickers on the sun visors, driver's shock tower, and the fuse boxes. Thought I would take pics of the engine compartment stickers incase I screwed them up. What is the best method for removing the visor and engine bay stickers? Thanks <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
The engine compartment stickers are tricky, they are "tamper" evident. Pull them off slowly, and MOST of the glue will come off. You will see a big chunk of white goo get left behind. Again used Goo Gone to remove the glue, takes quite a bit of work. Be careful not to use any super strong solvent or the paint will come off. The paint in the engine compartment is very thin!
The fan belt routing sticker and the emissions sticker can be ordered with the part number noted on them for future reference.
Good luck.
AHHH <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> GM PAINT
The visor stickers came of easily after heating them with the hair dryer. Put pressure against the fabric an it is still tight. Just a little glue to clean off.
The accessory belt sticker came off intact. Stuck it to a card an stowed it away in the owner's manual. Very little glue to clean up. The large sticker was another story. It separarted when removed. What I had was a clear sheet in my hand and alot of white chit on the fender well. The goo-gone took it all off.
No paint was lost in the process. Should have done this when the car was delivered. <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
