Rear SLP Bilsteins/Heater Hose mod done
Old 06-09-2009, 09:01 PM
hitmanws6's Avatar
Default Rear SLP Bilsteins/Heater Hose mod done
I had nothing to do today so i figured id knock these mods out. Total time with an oil change, lunch and going to Kragen to buy a missing socket was just under 4 hours. This was my first shock install btw
Before Heater Hose:
After:
Bilsteins:
Old 06-09-2009, 10:17 PM
Striker's Avatar
Nice. Did you notice any difference at all after doing the heater hose mod? Any sounds that weren't there before? Rougher ride?
Old 06-09-2009, 10:26 PM
hitmanws6's Avatar
i havent driven it enough to know, i just took it around the block. the rear felt a lot tighter
Old 06-09-2009, 10:46 PM
RAWPWR3's Avatar
Nice, some konis up front with the stock springs on the lower perch would compliment the rears' stance.
Old 06-09-2009, 11:01 PM
hitmanws6's Avatar
i have the front bilsteins, but no time to do them
Old 06-09-2009, 11:12 PM
RAWPWR3's Avatar
Gotcha, do those have a lower perch as well?
Old 06-09-2009, 11:14 PM
hitmanws6's Avatar
i believe so
Old 06-09-2009, 11:20 PM
ZexGX's Avatar
Originally Posted by hitmanws6
i believe so
They do not.
Old 06-09-2009, 11:22 PM
hitmanws6's Avatar
oh yeah, i remember reading you have to reuse your stock one. thanks for reminding me Zex
Old 06-09-2009, 11:30 PM
RAWPWR3's Avatar
Oh well, just gives you a reason to get springs later on down the road.
Old 06-09-2009, 11:31 PM
naperws6's Avatar
Looks good I did it to my Hawk and I noticed a difference very harsh ride. The heater mod looked good but the rearend felt like when i would hit a bump that the rear end was not following the car. So I bought some strano springs and am much happier.
Old 06-09-2009, 11:33 PM
hitmanws6's Avatar
i went over a few speed bumps. im amazed how fast the rear responds now. my old deCarbons has 197 K so i knew nothing else
Old 06-09-2009, 11:37 PM
naperws6's Avatar
Maybe my Koni adjustable shocks were not on the right setting. Glad your
T/A has a better ride than mine with the hose mod. congrats
Old 06-10-2009, 12:01 AM
Blacked_Out_SS's Avatar
dumb question i know.....but what is the heater hose mod???
nice T/A BTW......
Old 06-10-2009, 12:10 AM
hitmanws6's Avatar
nice T/A BTW......
you take your rear springs out, take out the rubber isolator that sits on top of them, coil heater hose around the top of the spring, then put the spring back in place. lowers the car 1/2-3/4 of an inch and takes on time at all
Old 06-10-2009, 12:17 AM
ZexGX's Avatar
What I meant was I don't think that there is a "lower perch" for Bilsteins. Only Koni SA's have that...
Remove rear springs and upper isolator
Take 1/2" ID heater hose and insert around upper spring coil. Reinstall spring without factory upper isolator.
Old 06-10-2009, 01:01 AM
porksoda's Avatar
Just a hint for when you replace the front shocks...PACK THE CUP ON TOP WITH GREASE!!!!! I replaced my shocks with Bilsteins like 3years and 10k-15k miles ago and when I went to pu the new BMR springs in this weekend the top shock nut was rusted to hell! Plus I live in New Mexico where it hardly ever rains and there is never moisture in the air. I sure did pack it with grease this time after putting the new springs in.
Old 06-10-2009, 08:17 AM
'00_Z's Avatar
Looks good, I need shocks too and will most likely do the heater hose mod then. Hows the shifter handle working out for ya Hitman?
Old 06-10-2009, 08:28 AM
Striker's Avatar
So did you put the isolator back in if it was so bad?
Did anyone else do this mod and notice a big difference. Im sure their in there for a reason.
Old 06-10-2009, 08:57 AM
keith_AE2010's Avatar
Yeah, the reason is to cut noise.
Its a good mod for cheap. And like most other mods, its not right for everyone. But, this one is good if you do it right to avoid squeaking.
Quick Reply: Rear SLP Bilsteins/Heater Hose mod done
