Hurst Cue ball shift knob
Old Jun 18, 2009 | 10:15 PM
SLPGTP's Avatar
Default Hurst Cue ball shift ****
Ok... So I got a white cue ball shift **** for the stock (for now) shifter. No matter how I put it on it is upside down with R/5/6 on the left... Do I need to put it on without the "jam nut" or what? Cuz it is irritating that something simple is being difficult. lol
Old Jun 18, 2009 | 11:11 PM
Rebelphotog's Avatar
Umm...I don't think you understand the concept of the jambnut. What you do is, screw the **** on (with the jambnut already on, and screwed all the way down) until you can't turn it anymore. Once it's tight, it will (and appearently this is the case) probably not be aligned correctly. Unscrew it until the shiftgate lines up the way you want it to. Hold it in place and back the jambnut off until it's tight up against the shift ****. Tighten it down and voila. You're done.
Old Jun 19, 2009 | 09:49 AM
SLPGTP's Avatar
Yeah the nut confused me. Tightened it all the way on. Then it was upside down. So then I just use a wrench to turn the jam nut back until it's positioned right. Then I got confused by your post. Sounded like I bring the jam nut back down to the bottom of the threads and done? What prevents the **** from moving again?
Old Jun 19, 2009 | 12:21 PM
Once the **** is where you want it, you turn the jambnut so that it moves up the stick, towards the ****. It will tighten up against the **** and hold it in place. It's kind of hard to explain, but hopefully you understand what I'm trying to describe.
Old Jun 19, 2009 | 12:49 PM
naperws6's Avatar
Correct!!!!! What he said
Old Jun 19, 2009 | 01:04 PM
SLPGTP's Avatar
So get the nut to the bottom, thread on the **** to where it looks good, then loosen up the nut so it goes up in to the **** as far as the wrench will allow. Sound about right?
Old Jun 19, 2009 | 02:15 PM
Mean Green z28's Avatar
Exactly, the jam nut "jams it" in place
Old Jun 19, 2009 | 02:27 PM
litemup02's Avatar
Yeah defenatly hard to explain I always turn the **** slightly to the left of where i want it, tighten the jam nut against the **** then twist it into place. You just gotta screw with it til you get it right
Old Jun 19, 2009 | 02:30 PM
Ice78Transam's Avatar
If you have a short stick, flip it around. and twist harder.
Old Jun 19, 2009 | 04:13 PM
SLPGTP's Avatar
I don't have a short stick but wish I did. Since I can't afford a short shifter right now. lol So I don't need to mess with the actual shifter do I? Just the ****?
