Custom door panels (writeup/pics)
Old Jun 24, 2009 | 03:27 PM
W es 6's Avatar
Default Custom door panels (writeup/pics)
I got bored so I decided to try this project I’ve been thinking about for awhile; I wanted to make a 3D Bird in the door panels and recover the door panels with black microsuede. Here’s how I did it:
1) Remove the door panels and separate the cardboard backing from the rest of the door.
2) Strip the vinyl covering from the cardboard.
3) Using ˝” high density foam, cut the individual pieces of the bird.
4) Use a hot-glue gun to glue the foam pieces onto the door panel in the desired location.
5) With high-tack spray adhesive (use a brand that is safe on foam and fabric… I used Elmer’s) spray a coat on the entire door panel (to include the foam cutouts) and also on the backside of the fabric.
6) After 1 minute to allow the adhesive to get tacky, carefully work the fabric onto the door panel. This will be time-consuming getting it to stick around all the edges of the foam cutouts.
7) After allowing sufficient time to dry, double check that you have good adhesion and reassemble the door panels.
This took me several attempts and several yards of fabric to get the hang of it. Hopefully if you’re thinking of doing something similar, this will help you out.
Attached Thumbnails Custom door panels (writeup/pics)-door1.jpg   Custom door panels (writeup/pics)-door2.jpg   Custom door panels (writeup/pics)-door3.jpg   Custom door panels (writeup/pics)-door4.jpg   Custom door panels (writeup/pics)-door5.jpg
Custom door panels (writeup/pics)-door6.jpg   Custom door panels (writeup/pics)-door7.jpg
Old Jun 24, 2009 | 04:37 PM
Counted Out's Avatar
Nice work. That looks sweet.
Old Jun 24, 2009 | 08:11 PM
firehawk#682's Avatar
looks good i might have to try this someday. Where did you get your fabric from and for how much?
Old Jun 24, 2009 | 11:14 PM
DropTopBird's Avatar
How much of the material did you need to cover both the panels?
Old Jun 24, 2009 | 11:36 PM
JDECO's Avatar
nice work, gives me ideas thanks
Old Jun 25, 2009 | 12:26 AM
95greenbird's Avatar
just a little tip if anyone else does this, when cutting the pieces for the 3D effect use a razor blade and cut the pieces with a 45 degree pitch on the edges.
Old Jun 25, 2009 | 06:32 AM
W es 6's Avatar
I got the fabric from Hobby Lobby... A yard and a half was plenty for like $20
Old Jun 25, 2009 | 10:26 AM
Scira's Avatar
How did you get the panel with the switches and the door handle cover like that?
Old Jun 25, 2009 | 11:13 AM
FamousZ's Avatar
Paint?
The doors look awesome!! You said you got that suede at Hobby Lobby?
Old Jun 25, 2009 | 12:52 PM
motoo344's Avatar
Looks real good, I might try that and put SS or just recover them. I've been looking for ways to improve the interior.
Old Jun 25, 2009 | 02:44 PM
W es 6's Avatar
A couple hours of sanding, 2 coats of color, 3 coats of clear... that's all!
Thanks for the compliments, guys... I'm really glad it didn't turn out looking like ***!
Old Jun 25, 2009 | 08:26 PM
You mean a yard and a half per door correct? Thats what I thought you meant, but I just wanted to make sure.
Old Jun 25, 2009 | 09:01 PM
a yard and a half will do both door panels with ease. a yard of fabric is 54" X 36"
Old Jun 25, 2009 | 10:01 PM
Norway's Avatar
that looks sweet. i did something like that when i made a sub box for a friend but they were flames. the bird look so much more awesome though.
Old Jun 26, 2009 | 04:06 AM
Ah I didnt realize the fabric pieces were usually that wide. Haha I had a completely different shaped piece in mind. Thanks a lot.
Old Jun 26, 2009 | 07:14 AM
W es 6's Avatar
Ya a yard and a half will do both door panels.
Old Mar 23, 2012 | 03:52 PM
ZexGX's Avatar
Since OP is still an active member, what did you use to reattach the insert section to the door panel? Hot glue? How has it held up since then?
