cheap or free weight reduction mods?
Old Jun 25, 2009 | 01:56 PM
2000ws6transam's Avatar
Default cheap or free weight reduction mods?
ok car looks like its gonna be done the rest of the summer (trans is done) i took off all the smog and AC stuff and did racing seats. i can tear the whole car apart what else can i do to lose weight? i like my ground effects and need 4 seats.
Old Jun 25, 2009 | 02:02 PM
Twotonefreak's Avatar
One thing I did was remove all the heat shields underneath the car. I also removed the front sway bar and all the brackets for it.
Old Jun 25, 2009 | 02:07 PM
heat shields would be good, i do want to wire wheel and repaint a few rust spots. i still drive it daily so i have to keep that in mind. i was wondering about no matting and go with like a undercoating for the interior.
Old Jun 25, 2009 | 02:58 PM
ZexGX's Avatar
You can remove the stock carpet and replace it with lightweight aftermarket carpeting. Undercoating is heavy. If you like the low-rise Formula/V6 hatches then you can switch to one of those. They are lighter than the high-rise spoiler hatches, and a lot of people either give them away or sell them cheap.
Old Jun 25, 2009 | 03:32 PM
TORCHD 02 TA's Avatar
front and rear bumper supports..
I would keep all the heat shield on underneath the car.. They're there for a reason.. Plus all 5 of them prolly have a combined weight off less than 7 lbs?
Old Jun 25, 2009 | 03:41 PM
ZexGX's Avatar
It's his DD... Would you take out the only thing keeping someone elses car from shoving your cars engine into your lap?
Old Jun 25, 2009 | 04:19 PM
whytryz28's Avatar
I removed my front impact bracket and foam on both camaros ive owned.
From accident picture my dad has shown me (Fire fighter) if the impact is great enough to push the engine in the car, your pretty much gonna be fucked regardless if the bar was there or not.
Old Jun 25, 2009 | 05:10 PM
InsaneAuto86's Avatar
Mine, much stronger than stock!
Old Jun 25, 2009 | 05:18 PM
GoFast908Z's Avatar
Try this
https://ls1tech.com/forums/search.php?searchid=8088735
Old Jun 25, 2009 | 05:49 PM
x2jesse1x's Avatar
You have got to be kidding me? It would be more trouble then its worth. They all weigh about or less then 5 lbs total
Old Jun 25, 2009 | 07:52 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
https://ls1tech.com/forums/drag-raci...y-updated.html
