Old May 20, 2016, 01:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Lighting Guides
Print Wikipost
98-02 TA HID Conversion
Old Jul 17, 2009 | 12:30 PM
AF8LTA's Avatar
Default 98-02 TA HID Conversion
Anyone know where I can order a Conversion kit for the TA? I would really like to do a HID conversion. A guy here in huntsville has them but the place he got them from went out of business. Any help would be greatly appreciated! Thanks.
Old Jul 17, 2009 | 12:36 PM
csxfbird's Avatar
First off, there's a lot of things to consider when trying to install HIDs on a Trans Am. For starters, the car uses sealed beam housings, which no HID kit on the market will work, unless you modify the housings. You've got a few options, from worst to best:
1)Modify stock sealed beam housings to accept a standard size bulb (H7, H9, etc), and installed an HID 'kit'
2)Purchase a sealed beam conversion kit, which replaces the stock sealed beam housings with identically sized housings that are made to accept standard sized bulbs.
3)Do it right, and install projectors that are designed to work with HID setups.
The Lighting FAQ will tell you more than you ever want to know about why the first two options are less than ideal, and why the third is the best, and how to go about the swap, whichever way you decide to go.
https://ls1tech.com/forums/appearanc...hting-faq.html
Old Jul 17, 2009 | 01:33 PM
AF8LTA's Avatar
Thanks. Anyone on here done the conversion? If so.. how hard was it and was it worth the effort? I can always just buy the SilverStars, but I don't know how bright those are.
I found this site and I may get these..
http://ledgauges.net/catalog/product...products_id=64
Old Jul 17, 2009 | 04:08 PM
jmurray87's Avatar
https://ls1tech.com/forums/appearanc...-trans-am.html
Old Jul 17, 2009 | 04:21 PM
97ramsst's Avatar
Originally Posted by AF8LTA
Thanks. Anyone on here done the conversion? If so.. how hard was it and was it worth the effort? I can always just buy the SilverStars, but I don't know how bright those are[/url]
You cant "just buy Silverstars", they dont make them as direct replacments for our cars.
I followed the link above and did the HID conversion using Eurolamp housing and I love them....WELL WORTH IT!!!
Old Jul 17, 2009 | 06:52 PM
tripps's Avatar
I did the conversion, I'll pm all the info I used.
Old Jul 18, 2009 | 06:09 PM
integraxtc's Avatar
do a projector retrofit, not a ricey plug and play kit, even w/ eurolamp housings.
Old Jul 18, 2009 | 06:59 PM
99Ls1fever's Avatar
Will you PM me that info too. I just got a 2000 Trans Am three days ago and am going to start on that here in the next few weeks. Thanks
Old Jul 18, 2009 | 08:32 PM
pheer's Avatar
could i get that info as well?
Old Jul 19, 2009 | 12:13 PM
Scira's Avatar
Originally Posted by SlvrV6Camaro
I used this write up. Great info, really easy. The only thing i'm going to change is going for 5K bulbs. I have 8K in right now.
Old Jul 19, 2009 | 03:28 PM
AF8LTA's Avatar
thanks for all the help. I've figured out what i'm doing and ordering my stuff..
I'll post up some pictures and a small write up when I'm done.
Old Jul 19, 2009 | 04:43 PM
00badfnta's Avatar
They are some nice lights.
Old Sep 22, 2010 | 10:29 AM
Ws6kid.'s Avatar
How did u get the fods to stay on while the high beams on?
Old Sep 22, 2010 | 06:42 PM
98 WS6's Avatar
Check the lighting faq, there's a writeup!
Thanks for posting my write-up everyone OP if you need any help, PM me!
Old Sep 22, 2010 | 07:04 PM
APG12's Avatar
I used the LMC housings and they are awesome!
http://www.lmctruck.com/icatalog/cd/full.aspx?Page=65
Old Sep 22, 2010 | 07:48 PM
Raven02TA's Avatar
heres the way i went about it:
Here are the links:
Order the low beam headlight housings from this website. (part number 36-0302)
order the fog lights and low beam bulbs/ballasts from here.
http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
when you order the bulbs. you want
880 bulbs for your fog lights
and 9006 bulbs for your headlights.
be sure to order all bulbs in 35w
choose your color (ranging from 1000Kto 12000K)
you DO NOT need an HID harness. and you DO NOT need error code eliminators
thats it. other wise. plug and play
pic below are fog lights before and after, then low beams side by side and then driving shots.
Fogs before:
Fogs after:
Low beams undone/done:
Both done:
Driving shots:
Old Sep 22, 2010 | 08:04 PM
98_TA_EMLC's Avatar
Seen Raven's in person and will be doing the exact same thing.
$140+shipping said and done
Old Sep 22, 2010 | 08:21 PM
APG12's Avatar
Raven, what temp bulbs did you use?
Old Sep 22, 2010 | 08:52 PM
Raven02TA's Avatar
used 35w, 5000K color bulb
Old Sep 22, 2010 | 09:55 PM
APG12's Avatar
Thats exactly what I have. Yours looked like they have a slightly more blue tint to them.
