How to mount gauge in vent
Old Aug 5, 2009 | 01:29 PM
kdick91's Avatar
Default How to mount gauge in vent
I have seen it EVERYWHERE and I only need to mount one gauge and don't want a pillar so I thought I would throw it in the AC vent all the way to the left, but I don't want to tear into it without exactly knowing how. I google'd like mad, but nothing. Any tips?! How the heck is this done?
Old Aug 5, 2009 | 03:13 PM
bluetransam95lt1's Avatar
they way i did mine when i had one in was i bought this grommet type thing from lowes. it was hard plastic and its hard plastic grommet that goes in a computer desk to run wires through. the 2 1/16 gauge fit perfectly in it and it practically held itself inplace in the vent. its really hard to describe the plastic grommet thing.
Old Aug 5, 2009 | 03:16 PM
something kinda like this: http://cgi.ebay.com/ws/eBayISAPI.dll...91&refid=store
the top pops off its just a little cap then you have a perfect hole and edge for the gauge. im not sure what size gauge your running but i think with a 2 5/8 gauge theres not much work to get it to fit.
Old Aug 5, 2009 | 07:47 PM
kdick91's Avatar
I heard a 2 5/8" just fits perfect so I will try that. Ordered a Pro-Comp trans temp. Will let you know how it goes
Old Aug 5, 2009 | 11:15 PM
Spd-Kilz's Avatar
Assuming you have a Firebird, then yes, 2 5/8 will fit well. They are marginally too small, so you'll have to wrap them with something so they don't fall out.
Also, chances are good that you'll destroy your vent when you take it out. It happens.
Old Aug 6, 2009 | 12:30 PM
kdick91's Avatar
Ah, that's no good. I'm just putting it all the way on the left in the vent that is part of the plastic trim thing. I am going to try not to destroy it though. If I do, I can just score another at a salvage yard.
Old Aug 6, 2009 | 12:44 PM
FormulaZR's Avatar
I'm hijacking a little bit...but I need to put A/F, Fuel Pressure, and N20 Pressure gauges in my car. But, I don't want a pillar mount, and I live in Texas...so working A/C is a must. Do I have any other options?
Old Aug 6, 2009 | 01:04 PM
kdick91's Avatar
You can put a mounting bracket below and to the right or left of the steering wheel. Like these http://www.egauges.com/vdo_agrp.asp?...nting_Brackets I wouldn't do that though. If you get a double DIN adapter and a single DIN radio, you could possibly do a DIN mount. Like these http://www.egauges.com/vdo_indA.asp?PN=PAN-001 Or just eliminate your radio all together but, again, not something I would do. Hope that helps.
EDIT: Just found the "Wedgee" http://www.egauges.com/vdo_acce.asp?Subgroup=Wedgee
Poke around, see what you find, and post the results!
Old Aug 6, 2009 | 02:17 PM
Spd-Kilz's Avatar
http://6litereaterdesigns.com/store/...cPath=21_37_56
Old Aug 6, 2009 | 03:36 PM
70hemicuda's Avatar
i put my wideband in the tweeter speaker in the door. It fits perfectly with only the slightest amount of trimming. it angles right at the driver. only prob. is that its sorta low to have to look at.
[IMG][/IMG]
Old Aug 6, 2009 | 05:18 PM
Spd-Kilz's Avatar
[IMG][/IMG]
Holy ****! That's genius! Kudos to you!
Old Aug 6, 2009 | 05:23 PM
DopeFedZ's Avatar
One of the users on this site recommended Pro Flex part number 3001-22. I picked them up at Home Depot yesterday and works great in mounting a 2 1/16 gauge in a TA vent.
Old Aug 6, 2009 | 09:36 PM
70hemicuda's Avatar
thank you sir. just run the wires through the grommet with the rest of the door wiring harness
Old Aug 6, 2009 | 11:39 PM
kdick91's Avatar
No kidding man! That really is insanely smart. Like if I didn't have to give up my tweeter I would do that no questions asked. Haha I'm more particular about my music than my transmission! But other than being low like you said, that is beyond awesome!!! Props!!!!
Old Aug 7, 2009 | 01:04 AM
70hemicuda's Avatar
lol. make sure its even hooked up. mine wasnt. hahaahahaahha
Old Aug 7, 2009 | 01:22 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
I just used a bead of black silicone to mount my guages.
http://www.fquick.com/garages/viewga...wimg&id=270815
Old Aug 7, 2009 | 10:52 AM
kdick91's Avatar
Psh. Whatever, that's stock.
Spped Inc makes this little billet adapter thing for 2 1/16 gauges. If it was black, it looks like it would be pretty neat, but that brushed billet looks weird to me.
http://www.ls1speed.com/morephotos.cfm?cid=C0000803
