AC Knobs
Old Sep 29, 2009 | 09:39 PM
patriot1136's Avatar
damn!
Old Sep 29, 2009 | 10:40 PM
01SOMSS!'s Avatar
Originally Posted by Y2K WS6
i have a 95 v6 mustang and i'm picking up my second T/A tonight I"ll check and see!
wont work. my bro has a 95 stang too. i tried his on my SS and the rear inserts are different. i thought if they worked i could have just order the stang billet ones since they are only 20.00
Old Sep 30, 2009 | 01:08 AM
VIP1's Avatar
Copy & Paste Moderator
Originally Posted by HVAC-Tech
I looked at the autozone *****. They want work
Did you try them on and they won't fit?
Old Sep 30, 2009 | 02:00 AM
98 WS6's Avatar
Thunder Racing has aluminum ones. Or you could switch a whole T/A panel in. Other than that I'm sure you could get anything to fit
Old Sep 30, 2009 | 04:45 PM
1 Bad Ass Formula's Avatar
The aftermarket support for 4th gen FBody interior pieces is limited unless you come up with an idea yourself that will work. I think I heard that 96-98 Grand Am ***** will fit, but I don't think that's any better than stock. I do like the MBA ones & after seeing them in a few cars I think they are about the only good option but $30 is steep for one **** when to do it right you need 4.
Old Oct 2, 2009 | 09:26 AM
VIP1's Avatar
bump.
Old Oct 4, 2009 | 12:01 AM
01SOMSS!'s Avatar
bump,bump!
Old Oct 4, 2009 | 10:45 AM
redbeauty2012's Avatar
what if you filled in the rear cutout with bondo or whatever and then you mimicked the holes of our cars and put them on could anybody get that to work thatwould leave the possibilities almost endless. just throwing out ideas
Old Oct 12, 2009 | 08:32 PM
anyone think that will work????
Old Oct 12, 2009 | 09:05 PM
kain01's Avatar
Think everyone has given up on this one, though in my searching someone said that the truck ***** would work. Dunno if he meant S10/Silverado/Colorado/Tahoe or what. I have no access to anything except my wife's passat at the moment, and those definitely don't work.
Old Oct 12, 2009 | 09:09 PM
my dad has a tahoe ill see if those work. i also have access to a silverado.
Old Oct 12, 2009 | 10:10 PM
  #32
nightmarechevy's Avatar
I think the ***** from the Silverado and S10 are the same. I might go pull a **** off of my s10 and try them out.
Old Oct 13, 2009 | 03:45 PM
  #33
keep it posted on what you get
Old Oct 13, 2009 | 06:54 PM
  #34
The S10 ***** are clocked the same but the mounting point is flush on the S10 ***** and has a shaft on the Camaro ***** which slides into the actual control panel. Kinda hard to explain so I'll post a pic shortly.
Old Oct 13, 2009 | 07:40 PM
  #35
97ramsst's Avatar
I am not sure how common MBA ***** are...I dont think at all the shows I have been to I have ever seen (or remember seeing) another car with them. I bought a set of blue ones off the classifieds for $70 (all 4) and then spent about 12 hours sanding and polishing them.
Old Oct 13, 2009 | 08:42 PM
  #36
those are extremely expensive and honestly are not at all worth it
Old Oct 13, 2009 | 08:57 PM
  #37
97ramsst's Avatar
ROFLMAO...that can be said about my entire car!!!!
Old Oct 13, 2009 | 11:21 PM
  #38
whats up with the truck *****?
Old Oct 14, 2009 | 09:38 PM
  #39
TireSm0ke's Avatar
Bondo isnt going to be strong enough to take the stress of when you turn the *****, in fact fiberglass may not either and even if it did, were talking about a tiny hole here.
The only thing that might work is to create some kind of adapter, although that might only work for a flush mount style ****... Basically have a fitting with the female end machined to the stock selector shaft, and the male side machined to fit the position of the new ****.
Old Oct 14, 2009 | 09:39 PM
  #40
Cell phone pic. Camaro **** on left, S10 **** on right.
