Turn signal socket & Window motor
Old Oct 6, 2009 | 12:28 AM
Detoxx03's Avatar
Question Turn signal socket & Window motor
I've tried a search but came up with nothing. I'm looking for instructions on how to change out a turn signal socket cause mine burnt out and the window motor for obvious reasons. Mods I was not sure where to post this so feel free to redirect it. Thanks guys.
Old Oct 6, 2009 | 12:55 AM
Pitbull329's Avatar
The window motor I haven't done before.
The turn signal socket, you can go to an autoparts store and buy the socket. What I did was just cut off the socket. There's three colored wires. Just spliced the matching wires. That was it
Old Oct 6, 2009 | 02:37 AM
gun4hire's Avatar
The socket I would think is just a cut/splice...
The window motor on the other hand...
Here is a writeup I used when doing mine...
http://shbox.com/page/windowmotor.html
Old Oct 6, 2009 | 09:57 AM
Detoxx03's Avatar
Thanks guys
Old Oct 6, 2009 | 10:27 AM
Super-Bat's Avatar
I'd imagine it'd be similar to this:
http://www.fbodyonline.com/rear-side...nector-how-to/
As far as the window motor, just follow the how-to posted earlier.
Old Oct 6, 2009 | 05:09 PM
Detoxx03's Avatar
Would it be the same for the turn signals?
Old Oct 6, 2009 | 05:18 PM
slow's Avatar
http://www.ls2.com/forums/showthread...ghlight=signal
no reason to cut and splice,
This walkthrough is easy to follow. It worked great for me for 5 years before I sold the car.
Ryan
Old Oct 6, 2009 | 05:47 PM
slayerized6's Avatar
http://www.ls2.com/forums/showthread...threadid=15143
ps- when changing your sockets, dont do it from underneath from the access doors. pop the headlights and remove the bezel; youll have a lot more room to work with and you wont be on your back. before you take everything apart, make a diagram and write down where each color wire goes and how the new socket go backs together. i usually make dash marks and i line them up when i put it back together.
pss- when changing window motor, use a 6"-8" length of 2x4 to hold your window up. just stick it between the window glass and the bottom portion of the door.
Old Oct 6, 2009 | 05:52 PM
Detoxx03's Avatar
Ryan
Thanks guys. I'm gonna give it a go
Old Oct 6, 2009 | 06:35 PM
qwk93ta's Avatar
Ryan
This is what I did about six months ago and have had NO problems since then.
Old Oct 6, 2009 | 07:17 PM
Michigan BlckBrd's Avatar
wait front turn signal, rear turn signal? wha?
Old Oct 16, 2009 | 08:24 AM
Detoxx03's Avatar
Front turn signal
