LT1 Halo Lights
Also, I'm not sure that kit is still for sale. I can't get to it from any of the menu options on their site. How did you find that? Google?
Here is how you can do it yourself if you are interested:
http://bellsouthpwp.net/m/u/mulgeary/Hella90/
The Hella 90mm housings themselves are $55/$65 ea from Rally Lights
And yeah I've seen that install for the Hella 90s, but I want the halos as well. Where would I get just the Halos? I'll try to find out, but I do like that the Focuztech kit has a warranty and is probably put together pretty well... maybe if building it myself will be worth the savings I'll do it.
You can make your own out of Acrylic rod and LEDs or you can buy some pre-made ones (either automotive or PC ones which are much cheaper).
"It is for both. And no this is an exposed projector design---both modules were designed to be exposed to the elements and come certified from Hella for that application.
-Mike Turner"
That pic was in this thread (which is also listed in the Lighting FAQ)
https://ls1tech.com/forums/appearanc...hts-works.html
