Aeroforce Scan Gauge (Video Demo)
#141
Well this one is so cool, and you can increase the rate it reads. It saved me from buying a zillion gauges, and this one reads boost! I had a code in there, it let me clear it. I install mine in my A/C vent in my 1981TTA. Also I can cut my fans on, and off with it(high-low). Most of all it monitors Knock, when I get into boost it will save my engine!
#143
Never had any issues with it updating the information. As posted above, you can adjust the refresh rate. I have two complaints on mine. I can only set one announcement (might be an older version) and even with the brightness all the way down, its too bright for my liking at night. I've been debating on using some tint as a remedy.
#144
Yes I did a search and couldnt find a real a answer. So Im bringing this old thread back to life.
I really want to know if the IAC work for are cars with this Gauge?
I need to dial it in after a cam swap and use it to montior trans temps with my 4100 stall.
