LT1 tail lights on 98-02 camaro, get in here
I know this is in an old thread, but I'm planning on doing an LS1-LT1 tail light swap and I have a couple of concerns... If you trim the sockets and decide to change back to newer model tails, will they still fit? And if you don't rewire it like in post #6, will the turn signals and brake lights still work?
Thanks
Thanks
No it won't work. You cannot separate the Camaro's tail housings. Not easily anyway. They are pretty well fused together and you'll crack the lens trying to get it off. I've tried. You can cut them open but by the time you do that and find a way to reseal them you might as well just trim the bulb holes. Far easier and faster.
Here's why we can't change the lenses on Camaros. I busted the lens trying to get it off. They are pretty well fused together. You can see how I was breaking the glued plastic to get as far as I did. Took a couple hours of prying to get this much done, but it still ended up splitting and cracking the lens towards the outside of the light.
I was doing this because I wanted to see if I could get the lenses off for doing something else, and decided to try on this bad tail light set, and, well... Yeah, I'm not trying on my good tails!
![Name: 20140306_210143_zps4a0d7287.jpg
Size: 67.4 KB](https://ls1tech.com/forums/attachments/appearance-detailing/668243d1501791986-lt1-tail-lights-98-02-camaro-get-here-20140306_210143_zps4a0d7287.jpg)
![Name: 20140306_210320_zpse8fb40a1.jpg
Size: 76.9 KB](https://ls1tech.com/forums/attachments/appearance-detailing/668244d1501791986-lt1-tail-lights-98-02-camaro-get-here-20140306_210320_zpse8fb40a1.jpg)
#32
Hey Guys!.... Cheers to all in 2016.
I bought a product (tail lights) online, with 4 ports for twist-lock light sockets (not advertised): My OEM tail lights have 2 sockets each. Anyone tried to get new tail lights and found this has happened?? Im tempted to just get 4 more and split the wiring,.... but, is that wise given the voltage?
Thanks,.... stay cool.
#33
