Gauge Overlay
Here's why:
If you 're using stock bulbs, goodluck seeing the numbers at night (you'll be trying to go through stock overlays AND these stickers). As for the matching up of numbers, it was a real pain in the *** as it is a sticker. (You need to wet your cluster and put the stickers on and slide them around until you think they might look good) Then you plug the cluster in real fast to try to make them light up but try not to let any water get into the cluster...then you remove it again and hope theres still enough water under the sticker to move them around again. Then you keep repeating the process until you think it looks good. They never 100% do...but i got close.
The other thing that really pissed me off was that there was no part that covered the turn signals....and the little gauge symbols got covered up by the bezel. Oh well, I got what I paid for.
Macewens are expensive, but they are easy to install and look good once everything is put back together. I lined them up as perfect as they're gonna get without even using water.
6LE/McNord gauges look better than Macewens b/c they are a full replacement rather than just an overlay. And what could be better than changing the lame stock text?! Just be aware that needle removal is required...
Either one of these options is a good choice....
Here's why:
However there is an easier way to install them. When I did mine, I placed a piece of plexiglass I had laying around between to blocks of wood (about 2' off the ground) and then put a spotlight underneath it facing up. With the gauges torn down to just the black face, you can see the light right through and line them up pretty easily. Yes you have to wet them down so they slide, but it only took me about 10 min to do all three overlays. For what I paid I love the result. It's a great alternative for those who can't afford a $100+ overlay.
I don't want to remove my needles. I remember when full replacements became popular a while back (before 6LE was a sponsor), a third of the threads that featured them followed up with people complaining about the gauges being slightly off. So I'd rather just avoid the possibility.
On the needles, I actually was just having a conversation with out calibrator today as Sommer has designed a new product we'll be showing off really soon...
Anyways, the stock gauges have a function of setting themselves to zero whenever there is power loss so as long as you get the needles back in the general area and then pull power to the cluster (like pull the cluster out or pull the fuse out, not just turn the car off) they will "sweep" to zero and reset... New info I'll be passing along after we tested it out...
I wouldn't let that sway your decision.
The needles will reset themselves to zero and the motors actually do all the work, it's not a spring or magnetic thing..... Even spinning the needles over and over won't effect anything. Just take a picture of your stock cluster/needles with your car at operating temp, and after the overlay install, get that baby back up to temp and replace the needles. It's that simple.
After messing with so many overlays and clusters now I realize why guys were having problems with the needles "not moving"... The motors are VERY strong, it seems that if the needles are pressed on "too" hard then there's contact with other plastic and you create friction and that stops the needles. The remedy is to just just not press on the needles as hard as you can or to just back it off after it's pressed on.
Hope that helps some of you a bit.
I have the exact ones the OP posted. They light up like stock without LEDs, are easy to install (they install like macewens, no water necessary) and have the bottom area where the turn signals are.
I just wanted to clarify that in case the OP was still considering the gauges posted in the 1st post.
Still thinking about with Macewens.
The idea of electronics and water just don't seem right,
just a couple of drops could slip down into the cluster and cause bad news.
To my knowledge, the ones I posted are not stickers so you don't need water.
