How do I install a 2 1/16th gauge in my AC vent?
Well my question is how would I go about routing the wire? I am getting the OBD2 scanner from www.pcmforless.com and Id need to run the feed from the diagnostic port all the way through to the AC vent where I want the gauge mounted.
Use a long drill bit & drill thru the plastic inside the dash over on the cluster side. Drill a hole just big enough to run your connector or wire thru & then use some black silicone to seal it up, or just leave it be. I didnt bother siliconing mine & unless your really looking in there you never notice.
Hole drilled without vent installed
