TransAm Front Breather Conversion
Old May 4, 2007 | 12:43 AM
Andros's Avatar
Default TransAm Front Breather Conversion
Hello everyone. I wanted to show you all my TransAm Front Breather Conversion. I used the search and couldnt find any pictures of LS1 TransAm Front Breather Conversions so I thought I'd add mine.
Tools
Power Drill
Dremel
10mm socket w/ wrench
Torx bit screwdriver
Items
24x30 Sheet Metal
1 bolt and nut
I started off by removing my front bumper and taking off the plate. After that I used a dremel to cut a hole. And I put it the bumper back on to see how it looks, It looks good imo.
This is the 24x30 Sheet metal I got from Lowes. i wanted an Aluminum Sheet Metal but they didnt have it so i got this metal one. I measured the length between the air dam to the 3 holes on the bottom front bumper. About 3 inches from the air dam then a horizontal bend of about 4.5 inches to line up to the 3 holes. After the measuerments I used a marker to and made a template on the sheet metal to cut with the dremel.
Here's close pictures after installing the sheet metal to the bumper.
Here's how it looks with everything installed standing away.
I'm going to put back on the air dam but I was really tired. I also plan on sealing the radiator and perhaps make a grill for the holes.
Old May 4, 2007 | 12:44 AM
HotRod68Camaro's Avatar
none of the links work
Old May 4, 2007 | 12:46 AM
Andros's Avatar
Edit. Sorry I dont know why the links didnt work. I works now.
Old May 4, 2007 | 12:59 AM
porksoda's Avatar
So your just gonna leave it open like that?
Old May 4, 2007 | 01:55 AM
DisturbingDaPeaze's Avatar
be prepared to replace mafs like crazy
Old May 4, 2007 | 02:22 AM
MetallicBluews6's Avatar
I do not like that at all. The only reason I would do cutting is if I had Forced Induction.
vipert/a's Avatar
whats the point of this? looks interesting
Old May 4, 2007 | 07:07 AM
Andros's Avatar
I'm going to make a grill for the holes.
The point of this was so the car can cool better with air coming from the front and not the bottom.
Old May 4, 2007 | 11:32 AM
reocamaro's Avatar
Covered w/ some type of mesh grill I think it has potential.
Old May 4, 2007 | 11:36 AM
mesh wont block everything. buy those mafs in bulk
Old May 4, 2007 | 11:44 AM
BIG_MIKE2005's Avatar
It still won't look right even with mesh. The only way to leave the front of a bird open like that is to put a big front mount intercooler in there. Otherwise it makes the front look unfinished & like a hack job.
Old May 4, 2007 | 11:50 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Um...his air filters will do that job just fine.
Old May 4, 2007 | 11:54 AM
_JB_'s Avatar
x2, sorry man.
Old May 4, 2007 | 12:08 PM
porksoda's Avatar
My car cools just fine without a massive hole cut into the front of it.
Old May 4, 2007 | 12:10 PM
reocamaro's Avatar
Well, I edited my original post after I started to ramble about FMIC when it seems to me that he wasn't going to go the FI route, and what's done is done, he might as well through some mesh up to make it less conspicuous.
Old May 4, 2007 | 01:15 PM
bboyferal's Avatar
You mean like my sig?
Old May 4, 2007 | 01:21 PM
cowboysfan's Avatar
seems the holes would create more drag.....
Old May 4, 2007 | 01:34 PM
Havok2's Avatar
telling you cus of expierence. but ok....filters will do their job, like they did on mine and i had to replace 3 mafs right?
Old May 4, 2007 | 10:23 PM
wannafbody's Avatar
Cut out the bird on the stock filler plate and glue mesh to the back of it- install it-it will look better than a squarish hole.
Old May 5, 2007 | 07:03 AM
Andros's Avatar
That's if I don't seal it to the radiator. As it is now yes it's sort of a drag but I know I'll be getting cooler temps.
My car is being set up for road racing. This isnt a daily driver or drag car.
And I think I'm gonna glue a grill on the stock front plate like bboyferal, it's nice and simple.
