Engine swap and engine bay build.
Old May 3, 2010 | 10:16 AM
  #41
LS1RedZ's Avatar
Lookin good!! Nice work for being in your driveway.
Old May 3, 2010 | 01:59 PM
  #42
scj's Avatar
scj
Thanks man, i sure do wish i had a garage to work in though, it would be so nice. but i'm only 18 so i deal with what i have to work with.
Originally Posted by ColossalCamaro
I do have those two major A/C lines for an LT1 that go back to the box in the dash.
little late now, regardless, i'm not going the a/c route anymore with the box now torn out of the engine bay and blocked off.
Originally Posted by Charlay
Looks good bud. But you better replace your window motors and make sure they work if your going the no A/C route .. I love Texas!!
window motors both work fine, so yeah.. haha
valve covers will be here later today, so look forward to seeing some pictures with those installed on the motor.. next is motor mounts and it's going onto the k-member to get it all buckled up on there with the speed inc alt and p/s relocation kit.
Old May 3, 2010 | 10:03 PM
  #43
brian_rs/ss's Avatar
good **** man.
Old May 4, 2010 | 03:01 PM
  #44
scj's Avatar
scj
Originally Posted by brian_rs/ss
good **** man.
thanks man.
got my valve covers in last night.
Old May 4, 2010 | 11:25 PM
  #45
scj's Avatar
scj
Old May 4, 2010 | 11:51 PM
  #46
scj's Avatar
scj
i have one question for you guys.. the valve covers have one hole in each cover, both have a screw in style baffle below the holes, but i'm wanting to run with just two valve cover breathers, can i fill with oil through one of the breather holes with the baffle installed? i really don't want to have to drill into the covers..
Old May 5, 2010 | 12:02 AM
  #47
Squirts11's Avatar
Impressive. I'm pulling my first motor/trans in roughly 3 weeks. Hopefully it goes just as well.
Old May 5, 2010 | 12:19 AM
  #48
scj's Avatar
scj
I've done a lot of stuff on f-bodys, and it took me less time to drop the engine/tranny than it did to change out the spark plugs and wires on this lt1 while the motor was in the car with the stock exhaust manifolds.
in other words, it was a hell of a lot easier than i thought it would be, and i did it alone. i'm 18 years old, 5' 11" and 125lbs, i'm not the strongest of the bunch. hhahaha!
Old May 5, 2010 | 12:48 AM
  #49
King Nothing's Avatar
did you leave the front tires on or did you put the engine and trans on a dolly and just wheel it out like that? my problem is i don't have enough room on the sides to jack up the car from the jack points so i think i'll have to jack the car up from the cross-member and then put four 6 ton jack-stands underneath the body mounts and lower the front suspension with the trans attached and then pull it out on the tires because i can't get a dolly where the jack will be in the front
Old May 8, 2010 | 02:40 PM
  #50
scj's Avatar
scj
i put it on a dolly, front tires off the car. i used an engine hoist to lift the entire car up from the front, then once it was high enough to pull the motor out from the bottom i put the car on jack stands at that height then moved the hoist to pull the motor on the dolly out of the front..
Old May 13, 2010 | 12:13 AM
  #51
Devils Mentor's Avatar
This is real inspirational stuff Bro, good for you! I can only imagine the BIG **** eaten grin you will have plastered on your face when you start that bish up for the first time, lol. Way to go man; BIG props to you!
DM
Old May 17, 2010 | 01:32 AM
  #52
scj's Avatar
scj
well i haven't really gotten much done on the motor or car really. just messing with wiring a little more and cleaning it up even more so, and got my breathers installed aswell.
DM
thanks man.
Old May 17, 2010 | 05:40 AM
  #53
White.Lightning's Avatar
Nice work
Like others have said....cam swap + tune FTW
Old May 17, 2010 | 09:20 AM
  #54
Irish350's Avatar
wow, its starting to look a lot like my 95 did...
for what a PITA it was (h/c w the engine in the car, header swap x2) that thing sure did clean up nice.
EDIT: none of my cars have gotten any engine bay wiring treatment; if i were you id DEFINITELY do all of the wire/cable hiding now, way less work, huge difference in appearance.
Old May 17, 2010 | 03:38 PM
  #55
scj's Avatar
scj
Originally Posted by White.Lightning
Nice work
yeah i know man, eventually it will happen.
I've already done all the wire/cable management and hiding along with all the vac lines on the motor as well. going from this when it was almost bone stock:
to this as of right now. it's tucked up pretty nice. :
relocated the solenoids on the passenger side to the back of the intake, deleted egr, air, a/c, relocated coil pack and icm module inside the car, all new vacuum lines and that's all the wires and vac lines that will be on the motor except for plug wires. i'll also be running the speed inc alt/ps. relocation kit.
Old May 17, 2010 | 04:50 PM
  #56
scj's Avatar
scj
picking up my tubular k-member tomorrow.
Old May 18, 2010 | 11:20 PM
  #57
scj's Avatar
scj
got my k-member today, bolted it up to the motor mounts and stuff also, just to test fit because it has to come off before i can get the motor out the door anyways. but it's a nice piece for $150.
Old May 19, 2010 | 12:56 AM
  #58
awesome bud!
Old May 19, 2010 | 02:24 AM
  #59
DCC!!'s Avatar
lookin good dude!
Old May 19, 2010 | 02:29 PM
  #60
scj's Avatar
scj
awesome bud!
Originally Posted by DCC!!
lookin good dude!
thanks both of you guys. more to come!
