HOW TO: Trans Am DRL Switchbacks
After seeing that the problem stayed with the same bulb as it was switched from one side to the other I am convinced that there is a problem with the bulb.
I emailed autolumination and they suggested the bulb might be on backwards. I fliped the bulb around and still got the same result. I emailed them a week ago letting them know this and asking for further help.
They replied agreeing to an RMA but insisting that I install load equalizers in order to make it work. I don't think anyone on this thread has needed to install load equalizers. I think they are just trying to get me to buy more of their stuff.
I am running Tridon EL12 flashers, my wiring is in good condition, my sockets are new, my housings are new (so water damage is not the culprit) and everything has always been protected with di electric grease.
What do you guys think? Do I need load equalizers? Is it the bulb? Do you think autolumination is trying to rip me off? Has anyone else had this kind of problem?
For those that don't know, switchbacks are LED bulbs that are amber when the headlights are not on and flash on and off like normal when the turn signals are activited. When the headlights are on, the light turns white and flashes between amber and white when the turn signal is activited. These should look great once I get my projector HID Kit from BLSolutions.
Here is a video after it was all complete. Sorry for my horribly loud headlights.
http://www.youtube.com/watch?v=3s_dCabHmtE
Parts:
2 - 3157 60 LED SMT Towers Amber-White (AW) Switchbacks from autolumination: $29.99 ea
PLEASE NOTE I HAVE BEEN HAVING PROBLEMS WITH THESE BULBS. I'M WORKING WITH AUTOLUMINATION TO GET THE PROPER BULB WORKING PROPERLY FOR OUR CARS. WE THINK RUNNING THE 48 LED SMT TOWER SHOULD WORK PROPERLY. PLEASE STAY TUNED UNTIL WE GET THIS FIGURED OUT.
2 - EL12 Electromagnetic Flashers from Napa: $10.99 ea
Here is a shot of the LED tower vs the stock amber bulb:
It is as simple as replacing the bulbs with the LED switchbacks and the turn signal and hazard flasher modules with electromagnetic ones to work properly with the LEDs.
Here are the flashers I bought at Napa:
The flashers are located under the dashboard on the driver side below the steering wheel. Remove the 2 screws and 2 bolts that hold the panel on to gain access. Also note these flashers DO still click when the signal is on. I actually like the sound better than the thermo ones...sounds less like a school bus and more like a regular car.
Turn signal flasher is by where your right knee would be. There is a clip that holds it inside a small rail. The clip is marked by a white mark on my car.
Hazard flasher is by where you left knee would be. I had to pop the clip completely out and flip it around and clip it on the outside of the rail because the new flasher is larger than the stock one. The pic shows the new one in place so it would look like the previous one before you pop it out from behind the rail.
All of this should also work with Camaro's but I believe only the 20 LED towers fit in the Camaro housings.
Special thanks to Brian @ BLSolutions for helping get this all figured out for my car.
Let me know if you have any questions.
