LED dome and map lights issue.
Old Apr 13, 2010 | 09:38 AM
f-bodyfanatic's Avatar
Originally Posted by LILWS6
i made my own map light a while back and haven't noticed them staying on i'll have to look now but i doubt they do they fade out like the oe bulbs and i also have like 60 leds up in there
Good lord that's a lot of leds up there. Mine fade out to just like the OE bulbs but then once it's "off" you can see a very little bit of light coming from them, it almost looks like glare.
Originally Posted by jcurrieta
would your door switches be wore out maybe?? 7 volts is kinda high? you sure the mutimeter setting is right and not .7 or something?
I've double, triple and quadruple checked everything. I had the mulitmeter set on auto and manual and made sure it was on the correct settings.
I'm gonna see if I can take some pictures of everything either tonight after work or this weekend and post them up.
Old Apr 14, 2010 | 08:39 AM
Well I took some pictures so you guys could see what's going on. These were all done with the doors closed and the keys in the ignition so that everything "should" be off.
+ and -
+ and metal
+ and screw
- and screw
+ and - without LED
+ and metal without LED
+ and screw without LED
- and metal without LED
- and screw without LED
Old Apr 14, 2010 | 09:19 AM
LILWS6's Avatar
now youve intreged (sp?) me into wanting to check mine. i don't have any pics of my led setup but i'm gana go check and see whats reading at mine for ya
Old Apr 14, 2010 | 09:41 AM
LILWS6's Avatar
ok I went out with the doors closed light off it goes to 0 volts. when on they run at like 12.2 or so on my meter. i got some pics just not shure wen i'll be able to get them on the computer right now. so i'm going to go with youve either got a short some where or the switches arn't turning off all the way or somethign with the bcm? the map lights do the same thing?
Old Apr 14, 2010 | 03:27 PM
LILWS6's Avatar
i did notice theres a set of 4 lights out in my group but that still leaves 52 lights on i counted theres 56 lol i got carried away i guess.
Old Apr 14, 2010 | 08:28 PM
Dammit. I was hoping it wasn't a short. HOWEVER, if it's been like this even with the old bulb in there and it's been fine then I don't have anything really to worry about. Plus I've had the bulbs in there for a week now and haven't had any problems.
I haven't checked the map lights but I know they're on just like the dome light. I haven't checked them because I've read that other people have had problems with the metal contacts coming loose and don't really want to risk having to go through all that crap since I already have this going on.
Old Apr 14, 2010 | 08:31 PM
Also, how bright is it with all those lights in there? I only have 9 lights and it's pretty damn bright.
Old Apr 14, 2010 | 10:04 PM
tmc2k1's Avatar
What is the bulb number for dome light? I ordered LED map lights but now I need the dome light. Thanks!
Old Apr 15, 2010 | 01:20 AM
ZexGX's Avatar
You definitely have a short somewhere... Like I said make sure nothing is grounding out on a reflector, including the map lights.
tmc2k1, you need a Rigid Loop Festoon (that's what it's called). That way it won't get shaken out of place when you hit a bump and cause an electrical short.
Old Apr 15, 2010 | 09:45 AM
BCKNBLK's Avatar
so did I read that right,,, your getting 11volts and 7 and 4 volts,,, all when its supposed to be off??
Old Apr 15, 2010 | 10:02 AM
Yes sir. The 4 volts comes from the negative on the negative terminal for the light and the postive on anything that should be a ground.
Old Apr 15, 2010 | 10:55 AM
  #32
tmc2k1's Avatar
I know that it's a Rigid Loop Festoon that I need. I meant what size?
http://www.ddmtuning.com/index.php?p...arent=101&pg=1
Will any of those festoon bulbs work?
Old Apr 15, 2010 | 11:15 AM
  #33
ZexGX's Avatar
No, you don't understand. It's a Rigid Loop Festoon. That's the type. They only come in one size. None of those bulbs are the proper replacement.
Old Apr 15, 2010 | 12:09 PM
  #34
tmc2k1's Avatar
Got it! Thanks
Old Apr 15, 2010 | 11:48 PM
  #35
bill12690's Avatar
i also got my LEDs from superbrightleds, and they do the same thing. never saw a problem with it really since its dim enough to where you cant even tell unless you look directly at it..
Old Apr 16, 2010 | 08:38 AM
  #36
BCKNBLK's Avatar
Originally Posted by f-bodyfanatic
Yes sir. The 4 volts comes from the negative on the negative terminal for the light and the positive on anything that should be a ground.
But still, you are getting 11volts when its supposed to be turned off too?? something is very messed up... Ive never seen this before... did you try a different multimeter.
It almost looks like thats not volts and its an ohm reading but iether way you probably know what your doing im just takin wild stabs here, I just cant see how you could get 4 volts from a neg wire lead to the metal on the car.
When did this first start happening,,, did you do anything,, anything at all to the car the same time this started happening other then the led install,, when installing the bulbs did you encounter any problems like needing to bend contacts on your dome light itself.
Old Apr 16, 2010 | 08:58 AM
  #37
Well I'm no electrical engineer but I know enough to hold my own.
When everything is "off" with the positive to positive and negative to any ground I get roughly 12 volts +/-. And no I haven't tried a different multimeter.
The ONLY thing I did to the car was added the leds, didn't bend anything.
Old Apr 16, 2010 | 10:22 AM
  #38
ZexGX's Avatar
Are you 110% positive that the map lights are not grounding out on a reflector and causing the short? I had the same problem as you but I got it sorted out after lots of experimenting and disassembly/reassembly.
Old Apr 16, 2010 | 11:27 AM
  #39
I haven't double checked but I'm about to leave work and will be able to check once I get home. I'll let you know.
Old Apr 19, 2010 | 01:25 PM
  #40
LILWS6's Avatar
its wicked bright my girlfriend hates openign the doors at night i can clearly see thru what i think is 35% tint on the back window wen there on.
