Engine Bay Dress-Up Project Begins!!! Pics!!!
Old 04-13-2010, 08:37 AM
223HAWK's Avatar
Looks Good!!
Old 04-13-2010, 09:28 AM
BCKNBLK's Avatar
very clean looking!
Old 04-13-2010, 10:00 AM
02gtp4now's Avatar
nice job i need to do some work on my engine bay
Old 04-13-2010, 01:19 PM
schtick's Avatar
Originally Posted by squirts11
Did you use silver engine enamel for the paint and clear engine enamel for the clear?
If not, what did you use, as the end result looks killer.
I just used the regular truck, van, SUV Duplicolor paint and clear...no high heat stuff. The intake shouldn't get all that hot since it's plastic so I don't really think that high heat paint is needed. Somebody back me up on that.
Old 04-13-2010, 03:39 PM
Charlay's Avatar
Looks great man. Keep going on the build and keep us updated
Old 04-13-2010, 03:56 PM
SPECIALIZED STAINLESS's Avatar
Looks good! I know it's a lot of work to get the intake that smooth.
Old 04-13-2010, 04:39 PM
ssbowtie1's Avatar
Looks great did you use high heat paint and clear coat?
Old 04-13-2010, 05:37 PM
schtick's Avatar
Thanks guys. I'm hoping to maybe work on it a little tonight. Maybe start polishing the throttle body. I still need to track down a tool to get my fuel lines off to paint before I can put the intake on.
Look at post #24.
Old 04-13-2010, 09:40 PM
YURVIEW's Avatar
Looks great..... wish I wasnt so lazy..... but i think my oil pressure sending unit is gonna make me start soon. so Yay, me
Old 04-13-2010, 10:18 PM
schtick's Avatar
That would be a good reason to do it. After I got my intake out, it looked like I was lucky and didn't break my sending unit off. Hopefully it'll stay that way when the new intake goes in.
Old 04-13-2010, 11:09 PM
Squirts11's Avatar
I have all the necessary components to paint my intake (and have had so for quite a while, just needed the time), but I had a question about one of the painting components:
I'll be painting the intake gloss black btw,
1. Adhesion promoter
2. Sandable primer (black)
3. Gloss black engine enamel
4. Clear engine enamel <<<<<<This is what I'm concerned about, as I wasn't sure how this clear enamel over previous black gloss enamel would look, and perhaps the clear you mentioned might be a better alternative.
Just a regular truck, suv clear coat rattle can by Dupicolor?
Old 04-14-2010, 03:20 PM
  #32
schtick's Avatar
I would think you'd be fine. The clear will just add more "gloss" to your gloss black. I just used regular paint because I had read (and thought myself) that high heat paint wouldn't be necessary because the intake doesn't get that hot since it's plastic.
Old 04-14-2010, 04:41 PM
  #33
crimson_bird's Avatar
yeah, for some reason people think EVERY thing under the hood requires high heat paint. which is simply not the case. most of the stuff in there doesn't get very hot at all.
Sooo, when are we gonna get some moar action? get on it. round 2, i'm waiting!!!
Old 04-14-2010, 07:15 PM
  #34
LS1_Sean's Avatar
Looks great!
I want to do this now.
Old 04-14-2010, 09:18 PM
  #35
99345hp's Avatar
you can paint the engine block with regular automotive paint and it will be fine. even cylinder heads are fine with regular paint, but around the exhaust ports might flake off over time.
Old 04-14-2010, 10:13 PM
  #36
schtick's Avatar
OK...I finally got a little time to work on it some more today. Bought the crappy little "tool" to get the fuel line off, which was a PITA by the way, so I painted the connecting line between the two fuel rails. I forgot the camera so the best I could do was with my cell phone...my bad. Hopefully I'll be able to get the intake on tomorrow evening. Anyway, here's some more teaser pics.
Fuel rails resting in place here.
Close up of crossover line next to intake.
Comparison of the old to the new.
Old 04-14-2010, 10:31 PM
  #37
meine96ws6's Avatar
looks amazing.. great job..
Old 04-14-2010, 10:37 PM
  #38
B Layton's Avatar
Default Looks Great
Can't wait to see it on the car.
Old 04-15-2010, 02:33 PM
  #39
Squirts11's Avatar
OP, I meant to ask, regarding the clear coat application, did you apply it when the color was still wet (within 10-30 min)? Or did you follow the directions on the suv, truck, and van clear coat and wait at least an hour after applying your last layer of color?
Old 04-15-2010, 05:10 PM
  #40
schtick's Avatar
I waited 30 min.
Quick Reply: Engine Bay Dress-Up Project Begins!!! Pics!!!
