Interest Thread - 93-97 Camaro Projector Setup - Input Needed
There is talk of BLS & 6LE looking into a projector setup for the 1998-2002 Camaro as well.https://ls1tech.com/forums/appearanc...histlered.html
(see page 3 for the hint)
This cash has been burning a hole in my pocket for so long, I got arrested for indecent exposure.
I was worried this kit would get me in trouble with the cops, but now the car is registered as an antique!
Haha, let's hear yours!
PS. BLS, I'm only teasing, patience is a virtue
Some fun with pic effects.
Tinted lens
if that's the case, i wonder if there's a way to mount another set of your projectors in the low beam area in a non functional way? just to have it there to even out the looks and bring balance to the front end. it's impossible for me to think of possibilities without actually having a set of your projectors though. what is the specific problem with the low beam area? the bumper corner?
the design of the projector itself looks good though, and they will definitely be the best option as far as lighting performance for the 93-97 camaro. it's gonna be tough to pull the trigger on these if it's going to unbalance the front end looks though.
When you refer to balancing the looks of the front end, that is always the challenge when installing a projector. The look is something that does not lend itself to an easy workaround. What we can do and you see one option there, is to smoke or tint the other headlight. Another could be to offer a simple plastic film with a circle cut out in the middle to simulate a projector eye. I personally would prefer the first option.
The purpose of the housing around it is to try and "square up" the projector so it flows with the rest of the front end. To us, this solutions offers the least amount of modification to the vehicle while providing the best light output for the space available.
We will still be tweaking the design for aesthetics. Wiring will be simple with a nice plug and play harness. You would simply move the replaced high beam lamp into the low beam position and swap the connections. As I mentioned already, the projector is a bixenon so you will have dual high beams to retain all lamps being functional.
