Interest Thread - 93-97 Camaro Projector Setup - Input Needed
Old Oct 5, 2011 | 07:55 PM
  #241
Shownomercy's Avatar
Man-Crush Warning
BLS, please design a very expensive unit that people on LS1tech assure you that they will buy.
Old Oct 25, 2011 | 10:23 AM
  #242
C_Rules's Avatar
subscribing...
Old Oct 25, 2011 | 12:56 PM
  #243
BLSolutions's Avatar
LOL.
On a serious note, we are going with a smaller projector which should allow for quad bi-xenon projectors or if the customer wants, just two projectors. We have the new mock design complete and just scheduling with a local customer for test-fitting.
Old Oct 25, 2011 | 01:51 PM
  #244
Turnin20s's Avatar
Originally Posted by BLSolutions
LOL.
I like this where do I send my payment
Old Oct 25, 2011 | 02:15 PM
  #245
coolmanvette75's Avatar
Gah this will never happen. BLS is too busy staring at his car in GMHTP
On a serious note, if smash isnt around for you, I'll be around for test fitting. Gives me an excuse to pick up that throttle body plate from you
Old Oct 25, 2011 | 03:30 PM
  #246
whytryz28's Avatar
LOL.
Now you have my attention.
Old Oct 26, 2011 | 09:54 PM
  #247
mtedenajimenez's Avatar
Yes!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 27, 2011 | 12:14 AM
  #248
The Dragon's Avatar
Still anxiously waiting
Old Oct 27, 2011 | 11:10 AM
  #249
4THGENCAMAROFAN's Avatar
Subbing
Old Oct 30, 2011 | 03:10 PM
  #250
Well, I just got back from BLS. We test fitted the projector and housing and everything went better than expected. The housing lined up almost perfect. It looks really badass. You guys are gonna love it. Sorry, cant share any pics but now that everything has been test fitted, BLS should be making some progress with it...
Old Oct 30, 2011 | 04:54 PM
  #251
Thanks for taking the time to stop over and let us take apart your car. As he mentioned, the fitment went very well so we are going to move ahead with the full production versions. As it is right now, customers will be able to go with either dual or quad bi-xenon projectors.
The new housings/projectors will fit in the low beam position so the look will be more appealing to those just looking to purchase the dual units. Installation will require extremely light modification to the headlight header panel (drill 3-4 holes per housing). You will not be grinding or cutting anything to get these in. The harness will be plug and play as always.
Stay tuned, things are going to get exciting.
Old Oct 30, 2011 | 05:02 PM
  #252
pancho toco loco's Avatar
sounds great. Will customers beable to purchase only the housing minus the the hid unit it self? Or your only doing it as a kit?
Old Oct 30, 2011 | 06:21 PM
  #253
Wing Zer0's Avatar
Yes!! Can't wait to see the final product. So I'll be able to tell if this is something I can finally. Incorporate into my Breathless Performance headlights. Brian you are still the man. I still have the old pm's from before you turned into BLS. That's another chapter though. Props and kudos still go out to you for what you accomplished.
Old Oct 30, 2011 | 06:39 PM
  #254
VIP1's Avatar
Copy & Paste Moderator
BLS, what projectors did you end up using?
Old Oct 30, 2011 | 07:53 PM
  #255
We could certainly offer the housings with projectors and you can supply your HID kit of choice. To have the bi-xenon function work, you will need the proper connectors though. Not hard but just something not to forget.
Haha thanks man. The market has been very responsive to our products and we do our best to maintain a high level of customer service.
We are moving ahead with the matchbox projectors. After receiving a set and doing some output testing, we were pleased enough with them to move forward. While a larger projector would have been ideal, there just simply isn't enough room without a heavy amount of modification. If the output was junk, we simply wouldn't even make them.
Old Oct 31, 2011 | 04:24 AM
  #256
fbodyrs96's Avatar
cant wait to finally get projects and some decent light output...
Old Oct 31, 2011 | 07:42 AM
  #257
Thanks and for the heads up, not a big deal for me
Old Nov 2, 2011 | 09:24 AM
  #258
camarolvr69's Avatar
Do u have a ballpark on pricing ?
Old Nov 2, 2011 | 10:28 AM
  #259
Working that out now as we move towards the production ready units. Look for the dual unit pricing to be comparable to our low beam only setup for the 98-02 firebirds however it will be higher. The materials for the housing and required machine work are more time consuming and expensive.
Old Nov 19, 2011 | 02:19 PM
  #260
camarokayden's Avatar
http://www.camaro5.com/forums/showthread.php?t=5916
