help removing driver power seat
Old Jul 6, 2010 | 05:44 PM
rggbly's Avatar
Default help removing driver power seat
the passenger seat was simple..just took off the 4 nuts.. now i'm on the drivers side and i cant find the studs coming out. my drivers seat is power whereas my passenger is not.. so can anyone tell me how to remove it? btw controls for the seat do not work and it's not the fuse so any suggestions on that would be much appreciated as well. thanks
Old Jul 6, 2010 | 06:34 PM
vjo90rs8's Avatar
should be exactly like the passenger side, 4 nuts. There may be plastic covers covering the nuts, those covers usually are held down with a philips screw. There is also a connector that you will need to disconnect before you lift the seat out.
Old Jul 6, 2010 | 06:45 PM
ROCNDAV's Avatar
hmmm, I usually have to use the switches to raise each side as well as slide it to the front and back.
Other than the required use of power to do so, it is the same as the passenger side.
Old Jul 6, 2010 | 06:49 PM
crimson_bird's Avatar
exactly what they said
Old Jul 6, 2010 | 10:49 PM
9WhiteCamaro9's Avatar
you prob know what imma say lol.... what they said
Old Jul 7, 2010 | 07:26 PM
rggbly's Avatar
yeah my problem is i don't have power, haha. i'll go to general maintenance i guess
Old Jul 7, 2010 | 07:34 PM
ROCNDAV's Avatar
Can you rig up a wire from a battery to the connector located under the seat (coming up from the carpet)?
Old Jul 7, 2010 | 08:33 PM
11SECSS's Avatar
Get test light ans seeif you have power on the orange wire under the seat .Check both sides of the plug.
Old Jul 19, 2010 | 06:17 PM
RedBowtie51's Avatar
Be careful not to pinch the wires.
Old Jul 22, 2010 | 07:40 PM
rggbly's Avatar
thanks fellas. used a probe on the orange wire which i found was corroded. bypassed the connector and the seats are working and i got them out
