Anyone have these headlights?
Old Jul 13, 2010 | 01:18 PM
hlaalu's Avatar
Do these aftermarket lights open up easier than stock?
Old Jul 13, 2010 | 01:23 PM
HAYSTACK's Avatar
Ive never opened up any OEM camaro lights but Ive opened 2 diff sets of the ebay ones and they were pretty easy. oven at 350 for 8/9 mins...
Old Jul 13, 2010 | 02:09 PM
PERFECT Z28's Avatar
They're only $150, try'em out.
Old Jul 13, 2010 | 02:14 PM
HAYSTACK's Avatar
Im sure the cutoff will be decent......unlike mine that I had to modify with my own shields.
Old Jul 13, 2010 | 10:13 PM
hlaalu's Avatar
yeah once i figure out the halo size i'll probably pop them in the oven
i am even going to spend an extra 10 bucks so i get the blinker lights too lol
Old Jul 14, 2010 | 11:23 AM
SparkyJJO's Avatar
You going to put CCFL halos in them? I was going to do that, you're beating me to the punch
Old Jul 14, 2010 | 11:37 AM
HAYSTACK's Avatar
I put CCFL's in my Xterra's housings. I tried using a glue gun but ended using automotive adhesive. The real CCFLs doesnt have any tabs on the back it just lays there flat. Most likely your gonna have to open them up to get an approx measurement.
Here is a comparison of the LED cheap halo, and a real CCFL
housing as it came.....
housing after paint, and CCFLs...
daytime on....
IMG]http://i200.photobucket.com/albums/aa261/jr_steele/DSCN1152.jpg[/IMG]
night time....headlights off BTW....
Old Jul 14, 2010 | 06:22 PM
rob69zombie's Avatar
Those look good Haystack.
Old Jul 14, 2010 | 11:26 PM
HAYSTACK's Avatar
thanks, essentially did the same thing to my ss lights, just removed the halos and called it a day.
Old Jul 15, 2010 | 02:33 AM
hlaalu's Avatar
Those are tight. Do you just rtv them in place or do they snap in somehow?
Old Jul 15, 2010 | 07:11 AM
HAYSTACK's Avatar
The halos that come with the lights have tabs that go through the housing, and then they are hot glued in. The CCFLs dont have a tab, they just lay in there, I tried hot glue but they vibrated loose 2 or 3 times on me....after that I used a clear automotive adhesive, used sparingly on top, bottom, left and right to hold it in evenly. You may find a better way but thats how I did mine.
Old Jul 15, 2010 | 09:41 AM
  #32
hlaalu's Avatar
Does it have to be a high temp adhesive or do the halos stay pretty cool?
Old Jul 15, 2010 | 10:14 AM
  #33
HAYSTACK's Avatar
I used a general automotive adhesive by loctite. It has worked fine for me....if you can get high temp in clear might as well be safe then sorry...you dont want to have to open them back up. I found that if you apply the adhesive, and use a hairdryer/fan on cool that it makes the glue get stickier faster...once u used the fan for a 30 secs or so then put the halo on.
One thing that is gonna **** you off, is once you heat the headlights up, and start opening them up, the weather stripping is gonna start to come off....maybe it wont with you but did with me. You can try glueing it back on but I used black gorrilla tape.
Old Jul 16, 2010 | 04:00 AM
  #34
MJs1FastSS's Avatar
OP if your looking to get HIDs lmk i can get a sweet deal local and 6 month warr on them as well i would recommend 4300k (5000K) pretty much the same but different people use diffent kelvin charts both are OEM white
Old Jul 19, 2010 | 10:47 PM
  #35
hlaalu's Avatar
lights came today, let the project begin!
