My custom interior GTO wanabe thread
At least you're doing something different though so props for that
This is really the only contact cement out of a spray can that I've found is good enough for automotive interior use .
Also , the A-pillars are made of Polypropylene plastic . Which is a very low surface energy plastic with horrible adhesion properties with any glue but a polypropylene glue like 3M dp8005( which isnt suited for what your doing) . So in light of that for future reference you have to go out your way if you want a long lasting bond , make sure you clean the part with soap and water , rinse good and air dry . Then sand with 80 paper to roughen the surface , then apply a adhesion promoter ...all before applying the glue . You need alll the help you can get bonding to polypropylene for any hope of it lasting a long time
GL with your project . The knit material is amazingly hard to get wrapped around the difficult curves by the dash area and the flat knit material is not stetchy at all . I wrapped a couple a-pillars in this stuff and dont really wanna ever do it again
Their two main products that are being used in these applications are the DAP Original Contact Cement (brush on application) and their Landau Top & Trim High Heat Resistant Contact Cement (uses a spray gun). That Landau seems to be a more resilient adhesive because of it's high heat resistance.
I have yet to use either of these but I've read some positive reviews and plan on using one of them when I start my projects back up. On another note, the updated pics look so much better!
