brake dust corrosion
![Unhappy](https://ls1tech.com/forums/images/icons/icon9.gif)
i never cleaned my wheels all last winter, and now they have those corrosion pock marks all around the lip of the wheel... the lip is polished and clearcoated i believe, is there anything i can do to make them look better? i know it they won't get totally removed, but can i make it look a little better? could i rub them with 1000 grit? ideas? thanks
1 Post
^ what he said unless you feel that you can do it with messing anything up but im the type that tries the easy ways first like what madice said cause i do trust myself to do stuff like wet sanding to an point lol
what will the steel wool do to the clearcoat and shine on the wheels?? what would i hafta do to get the shine back? wax? glaze? fine compound? all 3? thanks
If the clay goes over the surface rust and doesn't remove it, the wool should have a little more bite and remove minor surface rust.
As for the shine back - what's not making the wheels shine? Is there something wrong with the clear coat? Some pics would be good. Some compound could help.
Good Luck!
i just thought the steel wool would dull the finish, it won't? what about 000 steel wool? is that too abrasive? where do u get 0000 stuff? thanks guys...
