update on my engine bay thread
i dont like the flat ones. i know these have the coil mounts. i think they still lokks sharper than the plain flat ones.plus i wanted to have the option.
pulled the valley cover off.
here you can see the difference between the ls1<ls6 valley cover
ls6 valley cover in
I went ahead and did my plugs too.
kinda weird the all drivers side plugs were burnt but with a white shade and all the psg side were burnt/worn with a dark shade. I noticed the car has been bogging and jerking a bit at low speeds in the last few months. hopefully this tune up helps it a bit.
Coils mounted.
tomorrow i'll have to finish the valley cover. i just need to plug in the hoses and reinstall the mani. I also have to install teh valve covers and the coil relo kit.
update.
found a spot to mount the coils. i really like this spot since its hidden and its accessible by underneath the front bumper access underneath door.
psg side. i had to move the alarm horn a few inches.
drivers side. nice and clean
the cables came with number labels too. makes it easy to keep track of the coils.
now all i had to do is extend the coil harness with but connectors and some wire.
wrapped the wires in electrical tape.
this is how long they turned out to be.
and used wire loom to make it look clean and professional
before
after
got the manifold,valve covers and fuel rail back on.sorry for the pics. these are all taken after hrs.
I got the car started today everything works fine. i had a lil bit of smoking dues to old oil on the headders,but its all gone. everything is good to go.only problem i ran into is this.
i have to move the psg side coils a bit to the right. forgot our coolant reservoir have that big bottom belly.no biggie. I'll have to do that tomorrow night and start resembling the front bumper. friday i'll wash the car,sat full detail
