painting wheels wells?
did a search and cant find anything on it...im doin a full detail on my car...all four tires and wheels are pulled off the car and cleaning EVERYTHING...and i was jjust wondering if i could paint my fender wells back black and what kinda paint i should use...and does anyone have pics?
i painted mine with krylon satin paint for plastic i think its called fuzion.
there is a lot of grease dirt and grime so prep is key.
some simple green and a lot of scrubing or you can go to wal mart and get the bondo brand black trim dye its like 10 bucks its by the body filler and sand paper in the auto section.
it will dye it back black and last a good wile as long as you dont use any strong cleaners on the wheel wells when you wash your car.
When you did the bottom of your car with the underbody coating, did it make a huge difference on road noise inside the cabin? I've been wanting to do this for a while and then also dynomat the rear wheel wells...
Internet Mechanic
If it is that bad I would use a Semi gloss type paint.
