Old May 20, 2016, 01:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Lighting Guides
Print Wikipost
Interior led lights pics
Old Oct 23, 2010 | 07:53 PM
PewterSS#4302's Avatar
Default Interior led lights pics
converted all my bulbs to blue leds, and the dome lights to super white. I had use the gf car on the before pics. it looks better in person
BEFORE AND AFTER ................
BEFORE................................HAD TO USE THE G/F CAR FOR STOCK
AFTER...............................
After.........................
Old Oct 23, 2010 | 08:19 PM
WS9 Formula's Avatar
how did u do the steering controls? i need to change mine.
Old Oct 23, 2010 | 08:38 PM
i used a 3mm led the same used in the radio and soldered a resistor on it. i had to sand the top of the led a little because it was creating a hot spot and it helped dispersed the light evenly
Old Oct 23, 2010 | 10:06 PM
LE35thSS's Avatar
good job. i bet that does look amazing in person.
Old Oct 23, 2010 | 10:18 PM
DaRReLL's Avatar
very nize.....
Old Oct 23, 2010 | 10:29 PM
Screamin_99's Avatar
Thats very bright.. I did my Map Lights and My Dome in bright white and they have a blueish tint to them. Very freaking bright, but dont look nothing like that?
How do you get pics of them at night? My camera hates me.
Old Oct 23, 2010 | 10:43 PM
Sarge91's Avatar
I need info for the parts! Im so doing that!!!
Old Oct 24, 2010 | 12:19 PM
enigmah's Avatar
So all that work and you didnt replace the yellow/red led's on the gauges?
examples check engine light/break light/oil ect...
Its actually really simple.. i did it in mine. Ohh and you can actually do the thing that shows miles aswell. Its only 3 little led's that look like white boxes and you just solder 3 little 3mm leds in the places. Im going to do mine here soon and will make a big *** thread about it.
Old Oct 24, 2010 | 02:05 PM
djfury05's Avatar
where did you buy and what size are the map light and the dome light in back for the super brite white? Also, is the swap hard? Plug n play etc or is soldering involved?
Old Oct 24, 2010 | 03:42 PM
enigmah's Avatar
Soldering I involved on pretty much everything
Old Oct 24, 2010 | 03:51 PM
pm sent of list
I didn't want to do the check engine light and break light, I wanted to keep all of them amber and red. yes I have seen the odometer in blue and I dont like how it looks, just preference of choice.
I got them at Super Bright LEDs
map light is 4410-x9 Festoon bulb 4410-CW9 2.25
dome light light RL 4410-CWHP 9 1.00 Rigid Loop Festoon bulb
Swap wasn't bad everything is plug n play except the the radio, fog light and traction control switches and the steering wheel radio controls
Old Oct 24, 2010 | 03:52 PM
DaRReLL's Avatar
I could get the seek button off, but the two smaller ones below that I could not figure how to separate them. Any advise on how to separate the two lower buttons?
Old Oct 24, 2010 | 04:17 PM
Jimmy P's Avatar
Looks real good and amazing how bright the dome lights are..I ordered some blue LED bulbs from a sponsor here a few years ago, and they weren't no where near as bright as your domes. I do understand that the blue will omit less visible light, but its still no comparison. I wonder if the LEDs you have are simply better now than they were 2-3 years ago when I purchased mine.
Old Oct 24, 2010 | 04:36 PM
if your talking about the radio controls on steering wheel. I took it out in all one piece and then the cirucuit board snaps out of it on the back side
Old Oct 24, 2010 | 05:07 PM
jb98camaro's Avatar
how do you get to the bulb in the headlight switch thing? iv tried to pull it apart but i was afraid i was gunna break it..
Old Oct 24, 2010 | 05:09 PM
jb98camaro's Avatar
oh ya and where'd you get your map lights? those got some dang good light output
edit: sorry didnt read your post lol
Old Oct 24, 2010 | 05:13 PM
i had really small flat head screw driver, you have to turn it first then it pulls out
Old Oct 24, 2010 | 05:14 PM
Ruthless909's Avatar
Superbrightleds?
Love 'em.
Old Oct 24, 2010 | 05:21 PM
Ls1CamaroGuy87's Avatar
^This and this^. U shouldn't have to remove the smaller buttons on the steering controls. Superbright has a single SMD replacement for the headlight switch and there isn't any soldering required.
Old Oct 24, 2010 | 05:54 PM
jb98camaro's Avatar
sweet well ill be doin this soon then! is it just a 3mm led you used? or is it an actual led bulb?
