SERIOUS headlight issues!!! Trans Am people inside NOW!!
Yes it is safe to do this. The slim ballasts included with the kit are 55W so plugging into the 35W ballast won't hurt anything. The lamps are the same regardless of the wattage.
Also, after watching the videos, looks like you have one of two things going on. You have binding/poor gear mesh within the motor which caused your damaged gears or your motor is shot.
I'm leaning towards the first only because you have pulled the motors apart and confirmed your gears are chewed up on both sides.
Also, HIDs do not like to cycled very rapidly so try to take longer pauses between off/on operation.
I would not run the 55W ballasts in the foglight location. They may run too hot for those housings. The lamps and such will be fine but I don't think the foglight housing can take the extra heat.
And for what it's worth, BLS installed my BLS kit for me and they have never had any problems.
My fogs, on the other hand, are 35w DDM Raptor ("thick"), and I did have an issue with those earlier in the year--it worked itself out though, so whatever.
I'm using a DDM 55w kit too (non-BLS) and within the first week, my passenger light would only flash when I turned them on but not stay on, so I swapped ballasts with the other side and everything worked fine. Skip to a few months ahead and the passenger side did the same thing again and guess what? Swapping back to the original ballast that was now working on the driver's side did the trick. I guess that passenger side bulb gets bored with the same ballast after some time lol.
As for your headlight motor issue, it appears that the worm gear isn't meshing properly with the headlight gear. These motors are designed to stop when the circuit sees a certain amount of resistance. It seems as though your motors are still running when they're supposed to have stopped. By the way, you can recycle gears by rotating them 180 degrees.
I would check a couple of items first: HCM (headlight control module) module, this unit can cause all kinds of weird problems when they fail. IE: one or the other headlight popping up and then they both work fine. I've replaced my HCM twice in my car. You should also check to see that you have properly installed the wiring relay harness for the BLS kit. If you have a weak ground or 12v's it's going to cause problems. IE: like one light turning on and not the other. If you have the 55 watt ballasts these are more sensitive to voltage. It also helps to have the car running when you power your HID system on (initial voltage is very high on startup). If I try to start my HID 55 watt setup without the car running it will sometimes only turn on one lamp, but if I have the car on and barely above idle (I have underdrive pulleys) it will turn on both lamps every time. Your last problem with the gear getting chewed up might be due to end play in the gear shaft of the motor. If you ran your motors for a while when they were stripped you could have caused the shaft to wear the OD of the housing just slightly. If so, you will have movement when you raise and lower the lights. Hence; possible stripping of the gear. If this is the problem you will have to replace motors with new GM units. I actually purchased brand new GM motors and installed the new gears in the unit and everything has worked perfectly from that point. I have the BLS 55 watt HID setup in my 96 WS6 and it works beautifully now that I have all my problems solved
#32
Okay so here is my weekend update:
-Since my white plastic bump stop had a pretty deep gash, I took it off and put duct tape on it, and reinstalled it (flipped it around too)
-THOROUGHLY cleaned inside of gear housing and worm gear, removed all old grease and old epoxy
-Out of my 2 aluminum gears, I picked the one that had the least amount of damage and positioned it so only the good half was used (180 degree trick)
-Put new grease inside and resealed the cover
Now this is where I got a little crazy...since I ordered two of the T-Braces (bought an extra for the other side for safe keeping), I decided to just stick the second T-Brace on the back side of the gear. I think it may actually offer some additional support since it helps stabilize the axis the gear spins on.
Anyways, so I bolted everything back together and took it out tonight. Both headlights flip up and both HID's were working. I'm still not completely sold on the ballasts though. They're very fickle and I don't trust them. I'm going to continue to test everything out throughout the week. More than likely, I'll end up exchanging the ballasts for new ones.
#33
Do you open your headlights while driving? I went through the gear thing when I first got the car, got a set of OEM motors brand new and NEVER open or close them while driving. End of problems.
#34
If you had to put the T-brace on both sides of your motor housing to stabilize the gear, its clear you had shaft tolerance problems. In the end all that matters is it works now
#35
Next time one of my headlights isn't turning on, I will start the car and let it idle before trying again and see what happens.
#36
I've NEVER turned on the headlights while driving since I've installed the BLS kit (back in August).
#37
Seems like a good idea though since it offers additional support to the shaft that sticks out the back side. I suppose it would stabilize it more and prevent any wobble (IF that was the issue I was having).
#39
HCM module is in the upper drivers side area behind the headlight in the engine on (93-97) T/A's. The reason I mention the issue with voltage is because its of particular concern on a car with under drive pulleys (I have the ASP setup).
#40
I didn't HAVE to put a T-brace on the back side of the gear. I was just tired of dealing with it so figured what the hell. I was willing to try anything not to have to deal with this problem any more.
you should pm me.. you guys are SERIOUSLY over thinking this...
