To remove side mouldings or not ?
-probably the easiest is an adhesive remover wheel (google it), never used one, but the people who have swear by it, and when i looked into them they definitely seem to be the way to go. I'll use one when i remove the molding from my camaro.
-i just used a hair dryer (heat gun would be better, i dont have one) to heat it up and then used my fingers to push/pull an edge up enough to get a grip on it, then you just pull slowly, straight back towards the car , like a sharp u-turn, which will help keep it in one piece, as opposed to it just breaking apart, which it will do if you try to pull at a 90 degree angle away from the car. it helps if while you're pulling, you slightly push up on it with your other hand, in the place where its coming off the car. (hopefully you understand that, its hard to put in words). it'll also help to spray the adhesive down with wd40 or some goof off to help loosen up the adhesive as you work.
thanks crimson!
