To remove side mouldings or not ?
i've been looking at pics but i cant seem to make up my mind on removing side mouldings . while it looks cleaner , for some reason it looks kinda empty to me.. opinions and pictures welcomed guys !
http://www.flickr.com/photos/la-rue/5053024265/
http://www.flickr.com/photos/la-rue/5130429561/
So remove them, have them painted separately, and if you like the car without them, leave them off, if you want them back on, then reapply them once everything's all painted
-probably the easiest is an adhesive remover wheel (google it), never used one, but the people who have swear by it, and when i looked into them they definitely seem to be the way to go. I'll use one when i remove the molding from my camaro.
-i just used a hair dryer (heat gun would be better, i dont have one) to heat it up and then used my fingers to push/pull an edge up enough to get a grip on it, then you just pull slowly, straight back towards the car , like a sharp u-turn, which will help keep it in one piece, as opposed to it just breaking apart, which it will do if you try to pull at a 90 degree angle away from the car. it helps if while you're pulling, you slightly push up on it with your other hand, in the place where its coming off the car. (hopefully you understand that, its hard to put in words). it'll also help to spray the adhesive down with wd40 or some goof off to help loosen up the adhesive as you work.
