DDM Tuning HID Kit questions for those with them on their camaros
i would also like to know what might be causing this!
SAME HERE! my wiper motor will go to the on position and back to off randomly.. and when back in the off you can here this buzzing sound, but when its in the on position the buzzing sound goes away.. its so annoying..
Are you running the wiring harness?
When I didnt have the wiring harness, my left blinker would stay solid and I would hear buzzing. Put the wiring harness in, everything was fine.
Basically you take the positive and hook it up to a positive, usually the post on the side opposite the battery. After that you hook the ground anywhere on the chassis. Then you plug the two inputs to the stock wiring and the two outputs to the ballasts.
#36
**** DUDE, FIX UR FOG CONNECTION! i know it comes like that but if those tips arc ur gonna start a fire. get the connectors off of ebay for 3 bux!!!!!!
Dont wanna see anyone get hurt, NO ONE should connect it like this.
Heres the link buddy....http://cgi.ebay.com/ebaymotors/H11-H...Q5fAccessories
i got these and they worked perfect for the fogs.
#38
There's lots of places to tuck in the ballasts:
foglight HID ballasts
![](http://i305.photobucket.com/albums/nn238/dm100971/Camaro%20Pics/FoglightHIDballastignitor.jpg)
lowbeam HID ballasts
![](http://i305.photobucket.com/albums/nn238/dm100971/Camaro%20Pics/LowbeamHIDballast.jpg)
And even though they're not as bright as the 5K HIDs, the 10K HIDs are way brighter than the stockers:
![](http://carphotos.cardomain.com/ride_images/1/1571/4521/3927260298_large.jpg)
![](http://carphotos.cardomain.com/ride_images/1/1571/4521/3927260299_large.jpg)
![](http://carphotos.cardomain.com/ride_images/1/1571/4521/3927260300_large.jpg)
I'm not using the relay harness, and after 3 years, have had zero issues. Typicall they're needed on forgeign cars, or Dodges, Chryslers, and Jeeps. I also went with the 35W kits because of the heat issue. Although I did replace my stock foglight assemblies with a set of Hella Micro DE's because the stockers were crappy.
#39
Also those aren't for my fogs, it's the bixenon solenoid that taps into the highbeams.
thanks for keeping an eye out though!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
