cf wrapped "berger" panel
If its stretched really tightly then putting the lettering in might be hard, unless you take your time and use a really sharp razor knife and cut the letters out by hand.
Im not sure you might be able to make some little slits or cuts in the material on the insides of the lettering and then you could try to force the letters into place, It might work but it might not. If not you would almost have to cut the lettering out and then apply them. Depending on how much you cut, you might not be able to keep the Vinyl sticking to the rest of the panel.
I think it looks pretty good as is, and I would leave it alone.
Looks great OP! I actually like it pretty well. Thinking about wrapping my sailpanel in it.
Very nice work.. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Here's a real one.. Just in case..
http://www.aerokits.net/cart/index.p...oducts_id=1851
