Front Turn Signals 194 LEDS
I have the stock amber markers, but wut 194 LED can i use to make it brighter than stock?? Cant use an amber one cause it has to be clear right? do they make any?
1 Post
Yeah they were "clear" or better yet that off white like what the gauges were before you changed em to blue. I put amber bulbs in mine when I first got my clear corners cause of some of the police arround here. Then I swapped to the amber ones all the way around yesterday and havent thought about changing back to any other color. I have put the amber bulbs in my fiancee's car and look a hell of a lot better than just putting the "clear" ones back in. So I would only think that amber LED's in factory housings would look alot better than just factory "clear" bulbs.
The clear bulbs were just because of the orange lens. But a filament bulb tends to be on the yellow-ish side already. If you put a white LED behind the amber lens, you'll get some yellow look but it would be muted compared to putting a proper amber LED behind it.
Similar effect with a stock 194 bulb, if you put an amber one behind it it makes the color a little richer looking.
so ur saying i should get a set of amber leds for the stock amber turn signals in the front? i just thought orange led+orange housing wouldnt look bright? but i guess im wrong
