Fog lights without headlights?
1. Cut and cap the brown wire leading to the Fog Light switch
2. Tap the Ignition brown wire leading to the DRL module (Terminal F), and run this to the cut brown wire of the fog light switch.
3. Cut and cap Lt Green wire from high beams to switch. Ground Lt Green from switch.
4. Bypass DRL as usual (Lt Blue > Lt Blue / White and Dk Blue > Dk Blue / White)
5. Remove Fog Light Relay, Jumper pins F11 to F3.
If I'm correct, this should allow me to operate the fog lights via the switch regardless of the headlights being on, off, low beam, high beam, whatever.
Anyone want to chime in on this?
Hope your idea works though
I'm just throwing this out there, as it happened to me, but if your headlights flip up when you turn the switch on just for the parking lights, your headlight gears are on their way out.
I know this b/c it was happening to me before I changed to the brass gears. Once they were installed, I could turn on my Parking lamps (for the fogs) and my headlights would stay down. I don't know how it works in conjuction the way it does, but it does.
Hope this helps. (Sorry for the Hi-Jack)
