Sun Visors - DIY
Old Dec 14, 2010 | 04:26 PM
jimmyblue's Avatar
Moderator
I used the old passenger's visor to mark a trimming outline and cut the section
where the visor slides onto the arm.
(Not shown) I glued the core assembly up inside the outer skin. I used the
Weld-On #16 plastic adhesive.
When set, I glued up the edges and then trimmed the remainder of the piece.
I lightly sanded the edges to remove the raggediness of the trim.
Attached Thumbnails Sun Visors - DIY-folded_roughtrim.jpg   Sun Visors - DIY-traced_outline.jpg   Sun Visors - DIY-traced_outline_2.jpg   Sun Visors - DIY-drying_1.jpg
Old Dec 14, 2010 | 04:32 PM
jimmyblue's Avatar
Moderator
And now, the money shot....
Not terrible. The black doesn't exactly match the rest of the (now faded)
black interior, and the grain is not identical to the dash plastic. But it's close
enough to not stand out and not as bad as a floppy faded fabric one in my
book.
I think I'll run the side of a soldering iron around the edge to clean up the seam
and maybe squirt some black silicone into the outboard end to fill it, but that's
about it.
Attached Thumbnails Sun Visors - DIY-finished_installed_1.jpg   Sun Visors - DIY-finished_installed_2.jpg   Sun Visors - DIY-finished_installed_3.jpg   Sun Visors - DIY-finished_installed_4.jpg   Sun Visors - DIY-finished_installed_5.jpg
Old Dec 14, 2010 | 04:48 PM
Trans Am Jam's Avatar
I def appreciate you spending the time to try this out. I bet wrapping that in suede would be badass.
Old Jul 26, 2011 | 08:21 AM
Ls2SilverBullet's Avatar
Originally Posted by 01ssreda4
Sunvisors are for sissys. Do a visor delete and have your window tint guy throw you a tinted visor across the glass.
I've been wanting to do a visor delete for a while now. Did you leave yours like this or did you use the plastic mounting piece and screw it back in to cover up the hole?
I was thinking to use the triangular plastic piece with a black circular plate inside it to cover up the hole and make it look finished.
