***Blackbird Lighting Solutions (BLS) 98+ Firebird Proj. Headlight Retro GP 2011***
***BLS 98+ Firebird Projector Headlight Retrofit GROUP BUY 2011***
2011 BLS Kit Sale!!
2011 BLS Kit Sale!!
GP GOOD THROUGH January 31st - Spots are limited!
After a successful 2010, we are entering 2011 with a new GP. Get your car ready for the upcoming Spring weather in just a couple of months. We are pleased to offer the most powerful and best performing lighting system for 98+ Firebirds EVER available on the market
Why these outperform other lighting choices on the market today:
These lights feature:
- Optical technology from Hella (Well known manufacturer of BMW, Mercedes and other headlight components)
- Custom designed mounting system for ease of installation and easy adjustment
- Custom thermoformed impact resistant projector covers
- Custom designed aesthetic hardware covers
- Entirely Plug-N-Play No cutting, grinding, stripping or permanent modification
Other lighting options:
1) OEM Headlights Horrendous light output compared to 99% of other new cars produced today.
2) Sealed beam headlight upgrade (Silverstar) Marginally better than OEM with slightly better color however light output is still very poor.
3) Sealed Beam Conversion Allows for more lamp options and typically used with coated halogen bulbs producing better but not ground breaking results. Light output sometimes can be worse depending upon the lamp chosen and the coating on the aftermarket lamp.
4) E-Code Conversion Housings A costly conversion for better conversion housings but still lacking the focus and performance of a projector.
5) Sealed Beam Conversion w/ HID Kit This has been the popular upgrade with the 98+ Firebirds. While it offers color and, perceivably, the light output they want; the light patterns are very uncontrolled. Many have commented on the beam patterns with these kinds of setups and the light output can be sometimes dangerous for other drivers. Many questions regarding blinding other drivers requires the recommendation to "lower them down" reducing the effectiveness of the headlight system to begin with.
6) Fixed Headlight Conversion Certainly the most expensive option ($1K+) with questionable performance, fitment and love it or hate it styling. The low beam uses a DOT approved non-projector housing which will not have the performance of a quality projector.
The BLS Kit Difference:
The color everyone wants 5000K 55W Kit Pictured
Light intensity
Low Beam Cutoff Low on the driver side to not blind oncoming drivers, high on the right to give you farther distance.
Light Output at 50 Width and light intensity are like night and day
Light output at 30 with High/Low Beams On Light spread is more pronounced the farther away you are but nothing will hide from these while they are on.
Installation:
An installation CD will be packaged with each kit and if you can install a new headlamp in your car, this will not be much harder. Simple hand tools are the only requirement and will be outlined in the instruction manual so you have just what you need. Tolerances are very tight on these vehicles in the headlight area however these were designed to fit perfectly. The second picture shows that there is plenty of clearance with the front bumper since it appears closer than it really is in the first picture.
Lens to bumper clearance:
Adjustment:
To adjust the lights, it requires no extra work than how you already adjust your factory headlights. Adjusters can be accessed in the same positions as the factory points so no shroud cutting or disassembly is required to adjust the projectors.
Aesthetics:
Comparison from stock lamps to the BLS kit
Stock
BLS Kit
Customer Pictures
6000k
4500k
5000k
What You Get: Special Group Buy Pricing
Intro Kit: Low Beam Only - $475 shipped - Offered to those currently using a HID kit. New lamps required. (PM me for international shipping charges)
- Hella DOT/SAE 60mm Projector Low Beams
- Aluminum Mounting Frames
- Main Protector Cover Lenses
- Acrylic Hardware Cover
- Stainless Hardware
- Detailed Instruction Guide CD
Standard Kit: Low Beam Only - $525 shipped (PM me for international shipping charges)
- 55W Slim HID kit with Ballasts/Bulbs
- Upgraded HID Relay Harness with Plug-N-Play Connectors
Premium Kit: Low & High Beams - $850 shipped (PM me for international shipping charges)
- Hella DOT/SAE Projector High Beams
- Main Protective Cover Lenses
- 55W Slim HID kit with Ballasts/Bulbs Low Beam Only
- 65W Halogen lamps with Ceramic PnP connectors (Different lamps available at slight additional cost)
HID Color Options (Low Beam Only)
4500K White with slight hint of yellow
5000K Bright White with touch of blue at the cutoff - Standard
6000K White with Blue Tint
8000K Iceberg Blue
Halogen Options (High Beam Only)
Optional Lamp Choices - Extra Charge Applies (Kit will include standard halogen lamps)
Yellow All Weather - 55W - $40
Ultra White - 55W - $30
Pure Blue - 65W - $40
Titanium White - 65W - $55
Group Buy Info:
The Group Buy will last through January 31st or until I receive at least 10 orders. Construction time is 3-4 weeks.
If you would like to purchase the BLS kit, please PM me with the title "I WANT THE BLS KIT" and I will send you the payment information.
your retrofit conversions are very nice and i hope you sell a lot, but could you please stop buying up all the freaking hella 60mm modules? It'd be great if I could get my hands on some so I can finish a retrofit for another vehicle I own. They've been on backorder from multiple suppliers for weeks now
LOL. I hear ya but honestly Hella simply needs to produce and ship more of these things. We have badgered our suppliers quite a bit to let Hella know the market simply needs more of these in the US.
Hope you get your projectors soon and good luck with your retrofit.
