Can't get my HID's to come on??Help???
Old 01-20-2011, 09:05 AM
sscamaroburn02's Avatar
Default Can't get my HID's to come on??Help???
Okay I bought some eagle eye projectors and ordered the DDM HID Kit with H3 bulbs and a harness to run them straight off the battery. My problem is even without hooking up the harness I can't get my drivers side low beam to come on. I also tried with the car on in case they weren't getting enough power with it off. My halos, fogs, and side markers all work fine but no HID lights.
Here is how I hooked it up. From the bulb I ran and hooked up the HID wires to the ballast. The factory harness is plugged into positive on the ballast. Pretty simple it seems but no lights. I have the harness but wanted to see if it worked like this first. There are an extra set of wires on the bulb harness. Do i need these somehow??
somebody help please?
Old 01-20-2011, 09:25 AM
AwsmGy's Avatar
If you switch the ballasts around, does the problem remain on the drivers side?
Old 01-20-2011, 09:26 AM
what do you mean switch the ballast around? Aren't they both identical?
Old 01-20-2011, 09:30 AM
AwsmGy's Avatar
They should be identical, yes. But if you switch the ballasts and the problem moves from the drivers side to the passengers side then you can narrow down if it's an issue with the ballast itself or an issue with the power being supplied to the ballast.
When I had my Camaro I ran in to a similar issue, and it turned out the polarity of one of the ballasts I had was reversed. So I had to do some rewiring on the harness to get it to work correctly.
this is what I"m working with.
Old 01-20-2011, 09:32 AM
I will try this. How do you switch anything. Its all plug and play.
Old 01-20-2011, 09:35 AM
AwsmGy's Avatar
I'll make you a quick ghetto mock up of how to reverse the polarity, 1 min.
Old 01-20-2011, 09:40 AM
AwsmGy's Avatar
So if the issue is in fact something with the polarity all you have to do is change the red and black wires around at this point...
You can do that by pulling them out (they take some muscle, but they will come out) and then just swapping their position.
But before you start ripping apart your kit I would really try swapping the ballasts around and see if the problem shifts or not. I know that some people need an additional harness for their HID's to get them working correctly. I needed it for my fogs, but not my lows.
Edit: Just reread your first post and saw you got the harness. So ignore what I said about that.
Old 01-20-2011, 09:41 AM
Danny2tek's Avatar
Unplug the OEM connector off the ballast and flip it, the clip on the connector will be on the side its not supposed to be on..... GM engineering
Old 01-20-2011, 09:46 AM
I'm using the HID provided cables coming off the ballast. The wires plug into the others coming off the bulb.
BTW I have the harness but I was just trying to hookup everything simple right now to see if everything worked. I have a large system in the car so I got the harness so I would not have any lighting issues. My battery is new so that helps out alot.
Old 01-20-2011, 09:47 AM
I will try this first and swapping the ballast before I start pulling anything out. I shouldn't have to pull anything I mean I have read posts and nobody else has had to.
any other ideas it could be?
Old 01-20-2011, 10:31 AM
A350SOM's Avatar
Check the relay, I had one go bad before on almost a brand new kit.
Old 01-20-2011, 10:33 AM
APG12's Avatar
^This. Had the same problem, just had to flip the connector and reverse polarity.
Old 01-20-2011, 10:41 AM
okay if I reverse the OEM connector going to the ballast and they do come on it won't hurt to run it like that first and then hook up the HID harness will it? Won't overload the stock wiring or anything and burn stuff up will it?
Sorry all the questions...wiring is not my forte so I have alot to learn.
Old 01-20-2011, 10:44 AM
98 WS6's Avatar
Nope, you'll be all good, nothing to worry about. Just flip the harness around and see what ya get. Let us know!
Old 01-20-2011, 10:46 AM
will do after work this afternoon. Thanks guys for the help. Hopefully I can do some night driving tonite.
Old 01-20-2011, 11:16 AM
APG12's Avatar
Yea its either gonna work or its not. You wont damage anything.
Old 01-21-2011, 08:03 AM
Bingo!! Switched it around and they came on. But, the strange thing is when I hooked up my HID harness all the connections are correct and didn't have to switch anything around. Halos and lights look great.
One question though...the lights are flickering and not sure if its because my cam is shaking the car or if the light bulbs are loose. The fit right in the hole with no problems but the bulbs seem to be shaking or something. Has anyone else had this issue??
Old 01-21-2011, 08:42 AM
speedracer2536's Avatar
If tyhere flickering its your electrical connection..
Old 01-21-2011, 08:44 AM
everything is good and tight plug and play. Grounded it to my front support by the battery.
Quick Reply: Can't get my HID's to come on??Help???
