custom dash pad for 4th gen fbodies
Glue should be fine. Top foam and vinyl is done with 3M General Trim adhesive. Edge wrap and vent area done with DAP Landau top contact cement. The vent is glued in with hot glue, which also helps keep the under side down.
Really any decent adhesive should work since you're not stretching it by any means. Your usual failures occur when the material is stretched and wants to return back to normal or gravity. I used regular DAP contact cement on the first stuff I did. It worked until the first car show with the top down and then failed where it was stretched around the a-pillars and molded to the back of the headrests.
Not wanting to do it three times, I wrapped a spare head rest back using the landau top contact cement and left it outside all summer. No failures. Still need to redo my other stuff, but I want to get the rest of the interior finished before I start fixing things.
For those that haven't seen my personal car, here's the build log:
http://www.ms-fbodies.com/jade_ta.htm
Kevin D.
Kevin D.
