custom dash pad for 4th gen fbodies
Old Jan 27, 2011 | 09:20 PM
  #41
fbodyrs96's Avatar
that looks great, I need to redo mine now....lol
Old Jan 27, 2011 | 10:01 PM
  #42
Irisheer's Avatar
x2
Old Jan 30, 2011 | 11:20 AM
  #43
98Camarod's Avatar
Damn good work!
Old Mar 23, 2011 | 02:05 PM
  #44
Badz2810's Avatar
How did you do the vent and vent hole? I have everything else and it looks good but the hole looks like dirt
Old Mar 23, 2011 | 04:18 PM
  #45
GENE510SS's Avatar
that looks nice! I would do that also
Old Mar 24, 2011 | 02:56 PM
  #46
Cwillits505's Avatar
love it... been looking for something to handle that vent after I wrap my busted *** dash.. thanks for the write up!
Old Mar 24, 2011 | 04:26 PM
  #47
cemlsx's Avatar
cant wait till the day I do this alongside with some other interior pieces I want to get wrapped..
Old Mar 27, 2011 | 12:16 PM
  #48
shr00m-dew's Avatar
Cut-off wheel on a dremel and sand paper. You just need to shape it.
Kevin D.
Old Mar 29, 2011 | 11:48 PM
  #49
BizZzatch350's Avatar
Moderator
That looks awesome Kevin, great work.
Old Mar 30, 2011 | 04:50 PM
  #50
tbird31's Avatar
Sweet mother that is amazing work. I want to do the same thing but I want to delete the opening all together, as if it was never there.
If you lived closer I would SO pay you to do this...bravo man!
Old Feb 5, 2013 | 05:42 PM
  #51
Bigrieg's Avatar
Very impressive work
Old Feb 7, 2013 | 09:29 AM
  #52
DCC!!'s Avatar
That looks great! Il have to keep this in mind when mine finnaly breaks.!
Old Feb 7, 2013 | 09:54 AM
  #53
Image98's Avatar
Awesome work! Gives the dash a nice look
Old Jun 21, 2013 | 05:49 PM
  #54
00 CobraKiller's Avatar
I know this is an old thread... but where did you get the grill for the defrost? Home depot or lowes?
Found it.... over looked it!!!
Old Jun 22, 2013 | 10:26 PM
  #55
Firebirdmuscle's Avatar
Ah, my old car I sure do miss that one. Yes Kevin did a great job on it. I just wish that dash matched my new cars interior so I could have swapped them out. And that polished mesh did not reflect and shine in my eyes. I never had any problems with it.
Old Jun 23, 2013 | 02:57 PM
  #56
Originally Posted by shr00m-dew
What size hole do you use?
Old Jun 23, 2013 | 04:41 PM
  #57
86_irocz-28's Avatar
really cool need to do this to my dashpad where can i buy the vinyl wrap?
Old Jun 24, 2013 | 10:37 AM
  #58
v7guy's Avatar
Thanks for the compliments guys.
Glue should be fine. Top foam and vinyl is done with 3M General Trim adhesive. Edge wrap and vent area done with DAP Landau top contact cement. The vent is glued in with hot glue, which also helps keep the under side down.
Really any decent adhesive should work since you're not stretching it by any means. Your usual failures occur when the material is stretched and wants to return back to normal or gravity. I used regular DAP contact cement on the first stuff I did. It worked until the first car show with the top down and then failed where it was stretched around the a-pillars and molded to the back of the headrests.
Not wanting to do it three times, I wrapped a spare head rest back using the landau top contact cement and left it outside all summer. No failures. Still need to redo my other stuff, but I want to get the rest of the interior finished before I start fixing things.
For those that haven't seen my personal car, here's the build log:
http://www.ms-fbodies.com/jade_ta.htm
Kevin D.
Jesus man, page 3 is depressing. That had to be a difficult time.
Your car is beautiful. All the work you've done is very nice. You can tell you took your time.
Old Jun 30, 2013 | 08:10 PM
  #59
shr00m-dew's Avatar
I want to say it was their Monster grill, but I can locate the receipt.
Thanks for the compliments guys. I'm still pressing on on my own car, but there's a reason it's taken this long to get where I'm at.
Kevin D.
Old Aug 22, 2017 | 08:28 PM
  #60
Mumbles's Avatar
I realize this is an older thread, but I wanna say thanks to all who have posted here, especially shr00m-dew.
I used your steps to cover the original Upper Dash Pad that cracked as a result of the accident my Formula was in.
The Vinyl around the Defrost Vent could be a little smoother, but it may work itself out when I finally get the car back on the road and out in the sun.
Any how here are some shots...
Here is the Dash after repairing the broken piece with some Plastic Weld Glue and a Cocoa Puffs Box.
https://goo.gl/photos/FbTmK6iT98y314aS8
I couldn't find the Vinyl in any color but Black so here is my setup to paint it with SEM 15303 Graphite Vinyl and Plastic Dye. Its not a perfect match, but its really @#$%ing close.
https://goo.gl/photos/B4r5gPZrC4euKX8u7
I chose to add some Upholstery Foam in hopes that it would allow some forgiveness when wrapping the vinyl.
https://goo.gl/photos/9En8YxvhbLasJBVE9
Here's the Vinyl being glued in place. You can see a few air bubbles that had me concerned, so I wrapped a couple pieces of 2x4s in towels and placed them on it to hold the vinyl down and they came out fine.
https://goo.gl/photos/sBNSAiXAxM9LvmbN7
Wrapping the Vinyl. The clothes pins worked really well to hold everything in place, but kind of squished the foam and left the edges uneven. It seems to be bouncing back though.
https://goo.gl/photos/y46Wirp5RSAnvUU68
Here is the Vent Grille mocked in place. I cut the Security Light Bracket from the original grille and mounted it to the new one then opened up one of the holes to accommodate the bulb. This was only a mock up as well in this pic.
https://goo.gl/photos/BAxixt41xN4FPXrZ6
I have more pics that I need to upload, but here is a wide shot of the whole thing.
https://goo.gl/photos/RahqsGYeJ6jhDkH1A
I'll get some finished photos posted once I have them uploaded. I was hoping the link would show the photos, but I guess not. I was using photobucket until they recently decided to extort everyone, so I switched to Google photos and don't quite have it figured out. Anyways, thanks again to all.
