Oxidized Trim
Old Feb 22, 2011 | 10:52 AM
YellowTA1's Avatar
Default Oxidized Trim
i've looked, and can't seem to find anyone who's posted anything with this. Is there something that will take the oxidation off the trim around the hatch, t-tops, and windshield at like an autozone or o'reillys?
Old Feb 22, 2011 | 11:29 AM
VinR1's Avatar
you'd have to search but I specifically remember a guy getting some 'trim black' or something like that from Walmart, putting it on with sponges and loving the hell out of it
Old Feb 22, 2011 | 11:59 AM
YellowTA1's Avatar
do you know if that removed the oxidation, or just coated over it?
Old Feb 22, 2011 | 01:36 PM
t/a98's Avatar
Bondo restore black from walmart. One bottle will last years and it turns your grey trim rich satin black. Not shiny like armor all. It's like black finger paint. It doesn't remove oxidization but deposits black pigment in the pores of plastic. Don't paint plastic it out gasses and will bubble up over time.
Ps it's in the paint and bondo section not the car cleaning stuff
Old Feb 22, 2011 | 03:53 PM
YellowTA1's Avatar
thanks, I may give that a try, just really need to tidy up the trim and thought an oxidation remover would be a good start, then was gonna possibly use the back to black stuff....
Old Feb 22, 2011 | 04:00 PM
t/a98's Avatar
I have both. Back to black isn't bad. Better than armor all like products, but restore black is way better. I think gm even used it on an avalanche recall to fix their greying plastic body panels. If it wasn't Bondo brand it was the same idea differennt brand. I researched this a while back. Couldn't find much either. I scrubbed with vinegar as I read that worked. It didnt. I dont know of any other ways..
Restore black isn't permanent. They advertise 6 months. I've had mine that long and redid it today. It was a small improvement because it didn't fade but a small bit this whole time
Old Feb 23, 2011 | 06:48 AM
FASTFATBOY's Avatar
Kiwi water proof liquid shoe polish. Started using it YEARS ago on my 5.0's window trim. Will take a couple of coats but it works.
Old Feb 23, 2011 | 10:58 AM
Super-Bat's Avatar
Peanut Butter.
Old Feb 23, 2011 | 11:08 AM
YellowTA1's Avatar
Originally Posted by Super-Bat
Peanut Butter.
really? you just spread it out and let it sit or what?
Old Feb 23, 2011 | 11:55 AM
Callies Performance's Avatar
Peanut Butter.
Alone, or do you need to add Jelly as well?
Old Feb 23, 2011 | 03:05 PM
Super-Bat's Avatar
Depends on how hungry you are.
I like to accompany it with Apples. Yum!
http://www.youtube.com/watch?v=4f62OwctOBc
I doubt it'll last very long, but it's worth a shot, plus, the smell would be amazing!
Old Feb 23, 2011 | 03:06 PM
sempire's Avatar
Have you tries CLR? that **** does wonders.
Old Feb 23, 2011 | 03:13 PM
YellowTA1's Avatar
no, haven't tried that, but wouldn't that be bad for the paint if you get it on there accidentally?
Old Feb 23, 2011 | 04:33 PM
SteelCityYaga's Avatar
Try this:
Restoring The Look of Your Pontiac Firebird - Weatherstripping Revamp
You don't have to use the Back to Black, use what ever you want.
DO NOT SAND THE T-TOP TRIM - just put the product on there.
Also, tape off everything before putting the Back to Black, etc, it will be incredibly easier to coat the trim.
Old Feb 23, 2011 | 05:46 PM
therobman's Avatar
Peanut Butter.
it has oils in it only a temp fix
