Camaro switchback led question
Old Mar 3, 2011 | 12:21 PM
1sicLS1's Avatar
Default Camaro switchback led question
I just need to know what's the biggest size smt towers that I can get that will fit our corner lights. I know most use 20 but can you fit bigger? Pic in case no one knows what I'm talking about.
Old Mar 5, 2011 | 05:48 PM
1sicLS1's Avatar
Come on, Im sure someone has put switchback led's in there corner, just want to know whats the biggest that will fit ..>TTT
Old Mar 5, 2011 | 06:01 PM
StrobinSS's Avatar
I'm running the 20 in my corners so I can't help ya there.
Old Mar 5, 2011 | 06:03 PM
1sicLS1's Avatar
Do you like the 20's are they plenty bright enough? Reason why I wanted to go bigger because I thought the 20 wasn't a smd led am I wrong?
Old Mar 6, 2011 | 05:03 PM
AZ2ENVY's Avatar
Im running 60 LED SMD Switchbacks . I have also ran the 48 . I would honestly
say 60 is the limit though . They come pretty damn close to hitting in the housing .
Hope that helps . Here are the ones im running ....
http://cgi.ebay.com/ebaymotors/3457-...#ht_8310wt_909
Old Mar 6, 2011 | 07:10 PM
Purple94Z28's Avatar
Did you have to convert to the newer bulb fitting? Cause doesnt the 94 camaro have the round twist in bulb?
Old Mar 6, 2011 | 07:12 PM
AZ2ENVY's Avatar
Early production 94s and 93s have the twist in bulbs . Late 94s on up have the 3157
snap in style bulb . Mine is a late 94 car .
Old Mar 6, 2011 | 09:57 PM
Haha darn lucky man, mine must be early 94. Thanks
Oh btw man what did you do to your headlights to get them that like mirrored dark finish?
Old Mar 6, 2011 | 10:18 PM
1998MysticZ28's Avatar
45 bucks for two lights damn
Old Jul 8, 2011 | 10:16 PM
eanhl2004's Avatar
@ZL1LT1, why did you go from 48's to 60's?
Did you upgrade your flasher relay? if so, what specific relay did you get?
Do your hazards function properly?
Thanks
