New interior LEDs
Old Apr 6, 2011 | 06:28 PM
bayer-z28's Avatar
Default New interior LEDs
I REALLY gotta do the rest now. The others don't look right against the new bulbs.
before
AFTER. (They're supposed to be blue-ish white.. but look green)
New map lights too. These fit REALLY loose, but I made it work for now.
Old Apr 6, 2011 | 07:06 PM
FordHater's Avatar
Looks good! Nice work man
Old Apr 6, 2011 | 07:08 PM
floodofnoise's Avatar
They look really dim from 10-40 mph but it may just be the camera angle, lighting.
Old Apr 6, 2011 | 07:18 PM
Ls1CamaroGuy87's Avatar
10-40 looks pretty bad. Turn the bulb 180 degrees and it should light right up, other than that they look good. I am considering trying warm white leds to try and get a WHITE color rather than the bluish color.
Old Apr 6, 2011 | 08:41 PM
bayer-z28's Avatar
^ Yeah it is dim. Did they say you have to grind the top down to get them a little better? I'll mess with it tomorrow.
And was it me or was that gauge bezel/shroud a PITFA to take off? Almost seemed like I needed to drop the frickin steering column. Was just trying not to break or scratch anything.
I ordered white, but these are looking quite blue.. Oh well.
Old Apr 6, 2011 | 09:05 PM
southpaw0314's Avatar
yeah as said before spin the 10-40 mph bulb around to get it to light up.
Old Apr 6, 2011 | 09:17 PM
bayer-z28's Avatar
^ Any easier way to get the gauge shroud off any easier?
Old Apr 6, 2011 | 09:52 PM
Yeah, take the inside prongs/fasteners off next time, only the outside ones are required to hold it in place. I bend the whole thing to get it off and slide it out toward the headlight switch. Hey try these leds, they will be MUCH brighter than what you have now!
http://www.superbrightleds.com/cgi-b...FWLED-xHP5.htm
Old Apr 6, 2011 | 10:06 PM
bayer-z28's Avatar
Ah ok, I'll try that..
And I have the xHP5 bulbs. I thought I read somewhere about grinding the top down to make it disperse better but I was feeling impatient this afternoon.
Old Apr 6, 2011 | 10:34 PM
The ones I posted are SMD's, which are the brightest available without spending a fortune. Grinding them down would ruin them. The one behind 10-40 is simply turned the wrong way or has a bad connection.
Old Apr 6, 2011 | 10:37 PM
Sommer86's Avatar
What ones did you get, bayer? Mine are all HP6's and there are NO dim spots. Like Camaroguy said, try rotating it.... it may not be on.
Old Apr 7, 2011 | 07:36 AM
bayer-z28's Avatar
I've got HP5's. I'll mess with it later.
Old Apr 7, 2011 | 10:20 AM
chon79's Avatar
I had HP5s on my Camaro and had dim spots. I switched to HP6s and problem went away.
Old Apr 7, 2011 | 11:50 AM
Trans-Am Terrorist's Avatar
Thats what I have on my custom gauge too. Those 6's work wonders.
Old Apr 7, 2011 | 12:20 PM
chon79's Avatar
^sure do!
I don't have pictures from my Camaro, but I have a before/after of the HP6 LEDs on my TA.
Before:
After:
chon79's Avatar
Pictures make it look like it would be glary at night, but its not at all.
Old Apr 7, 2011 | 04:48 PM
GENE510SS's Avatar
did mine on tuesday with dome light, map and door handles imma do my radio, steering wheel, hvac and headlight switch hopefully this coming tuesday
Old Apr 7, 2011 | 10:48 PM
1BlackLS1's Avatar
Just did my interieor with DDM LEDS havent done the instrument cluster but now i want too whats the numbers for them?? also The lit up Transam above the radio is that supposed to light up or did u make it light up Id like to get my Camaro lit up like that....
