Headlight problem (HID)
Edit: I believe there is a mod you can do under the fusebox to make them come on together. Don't quote me on that though.
Easy enough to change that however. I changed it on mine because I didn't want the HIDs to turn off when I turned on the halogen highs. That would be pointless
Plus it is harder on the HIDs, they don't like being turned on and off a lot (which is another reason why HID in the high beam isn't always a good idea, it'll kill 'em faster).https://ls1tech.com/forums/stereo-el...same-time.html
) If that doesn't work I'm grabbing standard bulbs to see how they operate. hmmmm The Best V8 Stories One Small Block at Time
I think the circuit diagram you have is for a 1998 - 2002 Firebird.
1998 - 2002 Camaro
Low Beam: low beam bulbs only
High Beam: high beam bulbs only
High Beam: both low & high beam bulbs
) If that doesn't work I'm grabbing standard bulbs to see how they operate. hmmmm98-02 Camaros have the low beams turn off when highs come on. That is how they are from the factory. But as shown in the link I gave, it is extremely easy to make the lows stay on when you hit the highs.
Bulb type will have no effect on whether the lows stay on or not with the highs.
That's because it IS normal
This is funny...I'll have to get a better scan as it seems the dealer manual I have has the schematics backwards
lol The one I posted is labled as chevrolet and the other one that clearly shows the flip flop is labeled as pontiac. ^^ Ohh well, thats why I'm confused I guess
https://ls1tech.com/forums/15019850-post13.html
1998 - 2002 Camaro
