Stance thread ***DON'T QUOTE PICS!!!***
How do you like your GC kit? I've been thinking about switching to a GC/Koni DA setup next.
You should also definitely check out what your rear bump stops look like and see if they are trashed, that will cause the ride to be worse when you hit them hard on bigger bumps. Ideally you could ditch the rear eibachs for something a little higher.
I mean, I guess if your rockin a box-o-scion with a "mean" 100hp, those words, 60ft and turn dont have any relevance to you but for muscle cars, this IS the way "stance" is produced. If you want "hella flush" rides, well then speedhunters.com is only a click away...
some good lookin rides in here btw, keep um comin!
to take a position in an argument, a stand on a given issue;
refers to a particular standing posture
straight from the dictionary.....so every car has a stance.
everybody's car on her looks sick in every stance. and im sure the region and what roads you drive on can change the way you stance your car.
