Stance thread ***DON'T QUOTE PICS!!!***
Old May 21, 2013 | 07:13 PM
  #881
crimson_bird's Avatar
^That's strano springs with the isolator still in the rear? wow, seems lower than normal!
Old May 21, 2013 | 07:55 PM
  #882
stroked383HSR's Avatar
yep, strano springs with the stock isolator's. I used to have the hose mod in the rear with actually 2 pieces of hose and it sat to low compared to the fronts. I didnt like the rake plus i travel for work so i always have to pack my car in the rear.
Strano's are maybe 2 years old....you think they may be worn? and sagged?
So i put the stock iso's back in.
Old May 21, 2013 | 08:08 PM
  #883
definitely seems lower than the norm, but looks great!
Old May 21, 2013 | 08:18 PM
  #884
thanks bud! Im thinking about changing to rims to Gunmetal center TT's
I wonder what it would look like.
Old May 23, 2013 | 12:34 PM
  #885
Skraight's Avatar
Sitting on an incline, but new 19" wheels sneak preview.
Old May 23, 2013 | 12:49 PM
  #886
continuing to drop my damn jaw.. that's is perfect now! now go grab some rubbing alcohol and get rid of the red paint dots on the tires
Old May 23, 2013 | 09:32 PM
  #887
Skraight's Avatar
Thanks, I did it as soon as you mentioned it haha.
And just ordered that ebay lip someone else posted a while ago.
Old May 25, 2013 | 12:39 AM
  #888
rbl3's Avatar
Strano Springs w/Bilstein shocks
17x9/17x11 ZR1s
Old May 25, 2013 | 09:46 AM
  #889
01Z0H6's Avatar
I too am running the Strano's, bilsteins...
Old May 25, 2013 | 09:53 AM
  #890
damn! looks great with the new rims!
Old May 25, 2013 | 09:55 AM
  #891
01Z0H6's Avatar
Thanks John,... yours will too...
Old May 25, 2013 | 09:58 AM
  #892
ZForce1's Avatar
Both of those TA's on Strano's sit alot lower than my Z28 on Strano's/Bilsteins. Then again, every TA I've ever seen sits lower than a camaro from the factory. I've always like the factory stance of a TA over that of a camaro. With my Z dropped on Strano's it looked about the same as a TA factory. Crazy. I had a good 4" wheel gap factory. At least. I'm bringing the front down a full 2.2".
Old May 26, 2013 | 10:18 AM
  #893
JD_AMG's Avatar
Unfortunately all these cars sit differently from the factory. Different build tolerances, different springs sometimes (optioned or not), spring sag etc. From the factory both the TA and Camaro usually sit really high, mine definitely had the 4x4 option (I could fit my whole fist in the front fender gap).
Then to top things off the way the Camaros fender holes are cut are different then the TransAMs (the camaros fronts fender holes are bigger, and seeminly taller then their rears and flared out a little, giving the reverse rake look. The trans Am is just the opposite.
Old Jun 5, 2013 | 11:06 PM
  #894
Skraight's Avatar
All pictures are with a 35 MM Film Pentex ME Super camera, Unedited
Old Jun 6, 2013 | 02:05 AM
  #895
Revcore66's Avatar
^^ That looks unreal, love it, very well done!
Old Jun 6, 2013 | 03:04 PM
  #896
whiteheartbeat's Avatar
Skraight, that look sick! Would you share some info on wheels/sizes??
Old Jun 6, 2013 | 03:07 PM
  #897
Coppertone's Avatar
^ clearly you aren't running ANY exhaust.
Old Jun 6, 2013 | 03:26 PM
  #898
Skraight's Avatar
Haha what do you mean by that? I have hooker longtubes with o/r y pipe and borla catback.
The wheels are 19x9 +15mm and 19x10.5 +35mm
Old Jun 6, 2013 | 07:01 PM
  #899
stevesfbody's Avatar
It's weird seeing an fbody that low but I like it
Old Jun 6, 2013 | 07:15 PM
  #900
ChrisRZ28's Avatar
Skraight, I have some questions for you regarding clearance issues.
1. Did you remove your rear bump stops or does your car rest on them when aired out?
2. Did you do anything with the over the axle bend in the exhaust?
3. Are you running the stock torque arm? I measure 26 1/2 at the rear wheel and my UMI TA has clearance the tunnel at the rear end just a bit.
4. Have you done anything for clearance on the front?
Thanks in advance.
