Did driver and passenger wire mod and now lost RPM tach signal...HELP....
Just like the title states... My needle states at 0...
However I have a Autometer shift ligth with built in tack and it is working fine.
Any ideas? Would the wire I am looking for be on the driver side or passenger???
Thanks everyone
Thanks everyone
LS1Tech Premium Sponsor
Trace the wires from your camshaft position sensor to the PCM...likely one just got pulled out of its pigtail during the mod.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Thanks Matt,
I was doing some research and I switched to a LS3 block. Do I need to run a LS2-3 cam sensor? I bought the Ls1 to LS3 harness from TSP, with the sensor in the timing cover?
