Swirl Mark Annoyances.....
I have a couple of questions for all of you detailing folks on here. I'm in the process of really trying to restore the paint on my car. While it's not in bad shape as it is, it really could still use some work to bring out a cleaner, deeper shine. The bad swirl marks are the biggest problem here more than anything, especially on the hood and front fender area. It's from the previous owner not waxing the car and letting the sun beat down on it constantly.
For example, just last week, I waxed the entire car using Adam's Buttery Wax, which isn't really too harsh of a wax I'm pretty sure, it looked phenomenal when I was finished, the swirl marks were barley noticeable, paint looked great. Now, it was fine until just a couple of days ago when I washed the car and dried it with a clean absorber chamoi as it got caught in a downpour on the highway and it got pretty dusty at my job. I did all of this at sunset which IMO is the perfect time to wash a car. And keep in mind, I used Adam's harsher two-step wax application on the paint one other time and it worked great as well, but it just seems like the paint ate it or something once again after I washed it.
It's like I'll pull the car out of the garage the next day after a wax into the sunlight and it's swirl city all over again, especially on the hood and front fenders, doesn't seem like the wax is helping
Any reasons as to why this is happening? I have no idea and I'm considering getting it professionally detailed, my father thinks that we should keep working with it though...
Any input would be appreciated guys, let's see what you all think about this.
If the swirls are light you can try a cleaner wax, then polish and then a good finish coat/carnuba wax. If the swirls are pretty bad though it'll need to be done by machine and will be worth getting it done professionally. Then at least you'll have a clean slate to start with. Claying it will help but is mostly for removing oxidation and surface contaminants.
The swirls are highly noticeable in some spots on the car, I have to admit, the hood and fenders are the worst as I previously stated. My father believes that the paint right now still obviously needs work and it's absorbing all the wax and polish we've been putting on it, and it's going to take some time to get the swirls to go away completely. But, if that is the case, why is that everytime I wash it, it looks the same as it did before it was ever even thought of being waxed/polished?
Getting it professionally detailed is looking good right now to me though man, I don't know whether I should listen to what my Dad is telling me or whether I should bite the bullet and get it detailed.
To remove the swirls you're going to need a machine ( I recommend a Porter Cable since you're a novice) to remove them.
Also, just remember anytime you're touching your car you have a great chance of marring/scratching the finish. My suggestion, pick up a quality waffle weave drying towel from Meguiars or Adams or whatever your fancy is. I use Meguiars and they work great at pulling the water and holding over 2 times their weight. The most important thing is that it shouldn't induce any imperfections into the finish if done properly. That absober is not junk, but I only use them for unpainted finishes such as the wheels, windows etc. So keep that in mind.
There is so much bad information out there so get on a detailing forum, take a look at some of the folks who post pics of their work under halogens or a sun gun and ask them a few questions and go from there.
I hope this helps.
This is not a bad suggestion at all.
Use a quality Microfiber wash mitt and car specific wash soap. I use the Meguiars detailer line and I and my customers have had no complaints even with just a regular wash and no correction work.
Dry your car with a blower vac and a waffle weave towel or one of the REALLY soft microfibers. But dry it until there is hardly any water spots before you use a towel. Thats what I have been doing since we spent 8 hrs on the paint correction. Get some grit guards and do the 2 bucket method.
Thanks for all the suggestions here guys, very helpful. Seems like the two bucket method might be a good idea for the next time I wash it. What I have been doing was washing the car with Meguiars Gold Class soap and throwing in some water all into one bucket and a microfiber mitt and go to work on it. Then I just dry it with the absorber. I have small microfiber towels but I figured that the absorber would work a little better. Going to look into a waffle weave towel though, that seems like it works the best.
So, basically from some of the replies in here, it seems as if I have been wasting my time using different degrees and intensities of wax and polish on the car and it really needs a porter cable or buffer to get rid of the swirls permanently? Is there really no other way around this where I could get them out by hand?
You say you really want to fix up your paint. Invest (and it does pay you back when it comes time to sell the vehicle) on a porter cable buffer, pads, microfiber towels, and some good compounds. Then come thank me in two months. Honestly, the best thing I've ever done for my cars. If you're scared about using it, some youtube videos should set your mind at ease.
Should run you about $250. Well worth it.
Sorry for the bad info on the clay bar! I just looked it up last night, BadCompany VP is correct. I've never heard of the 2 bucket method and now that I think about it, it just makes sense...
Anyway, a buffer wheel would be a good investment for you right now and get a bunch of different foam pads for it.
Internet Mechanic
This is false. Clay bar will NOT remove any swirls. It will, however, remove embedded fall out, bug guts, tar, etc.
I hope this helps.
I hope this helps.
What your noticing is something that was already there, you need to train your eyes to see imprefections. The only issue with that is seeing imprefections everywhere. 98% of all street driven vehicles have some level of swirling, hell even garage queen cars never driven have them from the factory.
You need to clean the surface, remove contaminants, and then level the surface. From there adding layers of protection as well as correct washing habits will help avoid re swirling of your car.
Zaino is good stuff, but again it's not really a good shot to show when it's not a dead on picture in direct light. The bumper looks good from what little we can see and the small 'sun' shown in the reflection though.
