Old May 10, 2016, 02:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Exterior Guides
Print Wikipost
Plasti-Dip FAQ/Pics!
Old Jul 11, 2011 | 07:46 PM
ZexGX's Avatar
Default Plasti-Dip FAQ/Pics!
Post up your Plasti-Dip handiwork here! Include: pics, colors used, and application method.
Plasti-Dip FAQ (yes, I typed this myself):
  • What is Plasti-Dip?
    Plasti-Dip is a [temporary] spray-on, dip-in-a-can, or brush-on liquid that when dry, turns into a removable rubber coating.
  • What colors does it come in?
    Plasti-Dip comes in various colors - the most popular of which being black. Available colors are: Clear, White, Blue, Yellow, Red, Black, and CUSTOM (mix-your-own).
  • What does it look like when it's dry?
    When dry, it has a matte/satin finish. The thicker the coats, the greater the texture it has.
  • Why should I use it?
    You should use it to create temporary appearance changes. Its greatest advantage is that when you don't want it, you simply peel it off - causing no damage to most painted/bare surfaces.
  • What can I use it on?
    You can use it to temporarily paint wheels, black-out emblems, create "ghost" designs on your vehicle, or for simple things such as color-coding your tools or using it as insulation for electrical projects.
  • How long does this last?
    That depends on the method you use to prep it. Following the easy removal prep, it can last anywhere from 2 weeks to 3+ months. With a more aggressive prep method (adhesion promoter, sanding, or other prep similar to regular paint prep) it can last 4+ months. Complete coverage of the item you are spraying is key to making it last. Once an edge peels, not much can stop it from peeling. On my car, I painted the top of the exterior third brake light over a year ago, and it still looks the same as the day it was applied.
  • Where do I get this stuff?
    Most local hardware stores carry this product, such as Home Depot, Lowes, or Ace Hardware. If they do not carry it, they may be able to order it. If not, you can also purchase it online from various online stores.
  • Has somebody painted their whole car with this stuff?
    Yes, somebody coated their Infiniti G35 with this and posted the results in two places. Here are the relevant links which have pictures, videos, and tips:
    http://g35driver.com/forums/dfw-g35-...tidip-g35.html
    http://plastidipg35.blogspot.com/
    UPDATE: It has now become very popular to do a whole car, thanks to DipYourCar.com, which seems to have a market hold now for automotive related Plasti Dip sales.
    http://www.dipyourcar.com/
Application Tips
To make removal as easy as possible:
  • Wash, claybar, polish, and wax any painted surfaces before applying Plasti-Dip.
  • Wash and dry any other surfaces before applying Plasti-Dip.
  • Hold can 5"-6" away from surface.
  • Apply at least 3 medium coats of Plasti-Dip. The thicker the Plasti-Dip, the less it tears up when peeled off.
To make product last as long as possible (this is likely to cause permanent damage to the surface):
  • Prep surface with sandpaper, adhesion promoter, and/or general wax & grease remover before applying Plasti-Dip.
To make a clean edge:
  • Mask off everything with easy tape removal in mind.
  • Apply 3-5 medium to heavy coats with about 10 seconds or less between coats, then very carefully (but not too slowly) peel tape off before Plasti-Dip is dried.
If you let the Plasti-Dip dry, it will stick to the tape, and once that happens the only way to prevent tearing and get a clean edge is to use a razor blade to carefully cut the Plasti-Dip. Much safer to remove the tape when wet and start over if need to, than to take a razor blade to the surface you are spraying.
Click the link for more product details: Plasti Dip Protective Coating Products | Synthetic Rubber Dip Coating
Feel free to add more Q&A items or make corrections to what is above.
ZexGX's Avatar
DesertLS1's wheels:
VehicleCityLS1's t-top area:
LS1Vince's Honda Civic grille:
BadGuy7's wheels:
fbodyrs96's Ford Explorer trim:
94ss06gxp's gun:
karpesh29's wheels:
therealcreeper's sail panel test & hood:
ZexGX's Raptor hood "Blackbird" stripes:
BlaskO's wheel:
Old Jul 11, 2011 | 09:57 PM
02TransAm/Batmobile's Avatar
Now that explorer looks tons better.
Old Jul 12, 2011 | 12:40 AM
6898camaross's Avatar
I commend you for the effort you put into making this thread for all of us to use and enjoy thank you!
Old Jul 12, 2011 | 01:33 AM
camaroboy14's Avatar
Wow this was helpful I plan on doing alot to my car to see what it would look like
Old Jul 12, 2011 | 02:11 AM
Pete137's Avatar
Gonna use this for the CETA mod to see if I like it on my car or not. Will post pictures when I do it of course.
Old Jul 12, 2011 | 02:16 AM
Trans Am Jam's Avatar
someone wants a sticky thread and to be revered in the LS1tech community haha.. NICE JOB A+
Old Jul 12, 2011 | 02:22 AM
SteveLS19057's Avatar
Same here Pete137, got two cans earlier today, gunna do satin black ceta on gloss black car. gotta learn how to post pics.
Old Jul 12, 2011 | 02:29 AM
olskoolLT1's Avatar
my sail panel has some fade at the top, i was thinking about spraying the whole thing the satin black. i think it will look okay since my cars gloss black.. but if it looks like crap ill just peel it off
Old Jul 12, 2011 | 02:37 AM
01z's Avatar
01z
i need to do this to the trim around my windsheild, looks like the previous owner got wax on the plastic so it has thie wierd faded marble look
Old Jul 12, 2011 | 05:17 AM
94ss06gxp's Avatar
Default my latest plasti dip project.
sorry for low quality pics/
Old Jul 12, 2011 | 08:52 AM
raymond mckinney's Avatar
Gun looks great i might do one of mine now i see yours.
Old Jul 12, 2011 | 09:41 AM
LS1Vince's Avatar
just head over to http:www.tinypic.com and follow the directions, you want to change the size to message board, and then copy the [IMG] code. then paste it on here!
Old Jul 12, 2011 | 10:26 AM
karpesh29's Avatar
I just my snowflake stockers in plastidip yesterday afternoon.
Old Jul 12, 2011 | 10:39 AM
1badWS6's Avatar
I've had my emblems done on my g35 since I bought it. I'll get some pictures up tonight.
Old Jul 12, 2011 | 02:31 PM
Ryan Armstrong's Avatar
so im just curious has anyone done this over decals. i want to do my car flat black for a while but i dont want my decals to peel off with the plasti dip.
Old Jul 12, 2011 | 02:48 PM
ZeeSNuttS's Avatar
94ss06gxp that gun looks bad a$$ (Ninja) should have done your toes as well bro lol jk
Old Jul 12, 2011 | 04:22 PM
Blasko's Avatar
I Picked up 2 Cans today for my Rims. I'll probably get them done this week. and I'll definitely will post pictures.
I can't believe I forgot about this stuff until I saw this thread.
Old Jul 12, 2011 | 04:41 PM
ssteven's Avatar
I wonder what the heat range is. Exhaust tips black.
Old Jul 12, 2011 | 06:24 PM
therealcreeper's Avatar
to replace my bubbled sail panel:
because this hood was silver and I wanted to bolt it on temporarily:
